Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
Unknown Force Feed Lubricator ID?
this thread has 1 replies and has been viewed 563 times
Old 05-24-2018, 11:09:14 AM
naylorbros naylorbros is offline
Default Unknown Force Feed Lubricator ID?
HI! I am looking for a possible ID on this force feed lubricator. I posted a couple of pictures a while ago on the Steel Wheel Tractor section but will try again here. I bought it ten years ago or so and tore it apart and did not look at it again until a couple of months ago when I decided I might have a use for it. I got it reassembled yesterday but there are a couple of small leaks in the tank to fix so not quite done with it yet. It has single plunger pumps. The sight glasses on the pumps only drip oil if you push the bypass buttons in so you can see the oil drip. Doing this stops the oil delivery to the lube line. The oil seen dripping in the sight glasses returns to the tank. A picture of a assembled and a disassembled pumping unit. I few pictures of the pump and pump drive assembled and a couple of the assembled lubricator
Ken
ID:	311139   Click image for larger version
ID:	311140   Click image for larger version
ID:	311141   Click image for larger version
Old 05-24-2018, 11:10:58 AM
Default Re: Unknown force feed lubricator. ID?
The rest of the pictures.
ID:	311143   Click image for larger version
ID:	311144   Click image for larger version
Force feed lubricator id help naylorbros Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 04-24-2018 04:08:02 PM
Source for Manzel Model 25 Force Feed Lubricator sight glasses and other parts Robt. Oilers, Lubricators and Grease Cups 0 03-09-2017 11:35:57 AM
Detroit Lubricator No. 22 3-feed - sight feed glass scsshaggy Steam Stationary Engines, Traction Engines 5 02-24-2016 09:34:04 PM
How do you test force feed lubricator pressure primerk5 Steam Stationary Engines, Traction Engines 8 05-08-2013 08:43:23 PM
McCord Force Feed Lubricator Brian Nash Farm Antiques and Collectibles 1 01-10-2012 07:23:44 PM
