Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
Lunkenheimer Sentinel No.2 with Check Ball
this thread has 3 replies and has been viewed 618 times
Old 10-03-2018, 09:07:51 PM
Joe Huld Joe Huld is offline
Default Lunkenheimer Sentinel No.2 with Check Ball
I was looking through my collection of oilers for one to install in my 1920 Fairbanks Morse 1 1/2 horse engine and found this Lunkenheimer Sentinel No. 2 which has a lower fitting that is cross drilled and has a check ball. The size looks right to me for this little engine. Can anyone comment whether this is a suitable oiler for this application?
ID:	320147   Click image for larger version
ID:	320148   Click image for larger version
Old 10-03-2018, 09:44:13 PM
Default Re: Lunkenheimer Sentinel No.2 with check ball
Sentinels never had check balls, someone added the ball. It might work in your application but it is not a proper cylinder oiler.
Old 10-04-2018, 01:18:42 PM
Thanks, I have about 2 dozen oilers so I might still have one. What exactly am I looking for in a cylinder oiler?
Old 10-04-2018, 07:52:53 PM
A cylinder oiler will be closed on top with a plug of some sort so it is air tight also they usually have a vent tube in them which goes from the sight glass to the top of the reservoir and usually a check ball in the bottom.
Lunkenheimer No. 3 Fig. 1300 Sentinel Oiler jboyer1028 Hit & Miss Gas Engine Discussion 3 08-27-2013 10:15:20 PM
Lunkenheimer Ball oiler, Gas Engine Drip no less Randy Hart Hit & Miss Gas Engine Discussion 3 03-17-2013 10:03:58 AM
Check Ball Johnnyboy Small Air Cooled Gasoline Engines 4 01-31-2011 01:25:59 PM
Lunkenheimer check valves Preston wells Antique Engine Archives 2 07-11-2004 04:20:22 PM
Maytag Check ball Peter Riddell Antique Engine Archives 7 01-14-2001 01:05:42 PM
