Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Looking for toy steam engine dynamo advice
this thread has 15 replies and has been viewed 959 times
Old 11-13-2018, 08:23:20 AM
N0QBH N0QBH is offline
Default Looking for toy steam engine dynamo advice
I'd like to add a dynamo to my Jensen 75 and would like something with a reasonable amount of LED output.
Suggestions?
Old 11-13-2018, 08:41:21 AM
Nick Severson Nick Severson is offline
Default Re: Looking for toy steam engine dynamo advice
Watch for a used Psantama Blue Thunder on ebay.
Old 11-13-2018, 01:35:17 PM
I believe Jenson makes a generator of their own too. Not sure if Mamod or Wilesco made one.
Old 11-14-2018, 12:11:40 AM
I need to make a new/better video but this is what my Blue Thunder can do. A Jensen 15 lamp is no comparison...
The Following 2 Users Say Thank You to Nick Severson For This Post:
Old 11-14-2018, 08:02:50 AM
OK, I'm impressed!
I tried using the web link to contact the maker of Blue Thunder Generators, but it appears the web site email isn't working.
Anyone know the secret?
Old 11-14-2018, 09:24:12 AM
Just use a good DC motor, such as a capstan drive motor out of a tape deck, or an Axis drive motor out of an analog X-Y recorder. Best commercial motors are made by Bueler. Check your local university surplus depot for old X-Y recorders for cheap.
Doc
Old 12-17-2018, 07:55:19 AM
Adapted a Buehler DC motor to a generator and got it to light a blue LED quite brightly - provided I could keep a good head of steam on the Jensen 75.
It likes about 15 psi to handle making electricity and still have a little headroom. It's obvious solid fuel isn't going to be a long term solution.
What type of gas burner do you recommend for retrofitting a new Jensen 75?
Mike
The Following User Says Thank You to N0QBH For This Post:
Old 12-17-2018, 05:57:12 PM
BIX gas burners are my favorite. You will have to remove the shelf that holds your 75's Esbit tray, just drill out the rivets.
https://www.ministeam.com/acatalog/Burners.html
I have one of their gas tanks, but rarely use it. Instead I use the valve that screws directly onto the disposable cans.
Old 12-17-2018, 09:04:01 PM
Which size burner would be used in a Jensen 75?
I see 50mm, 67mm and 120mm.
My tray is 4" (100mm) long.
Old 12-17-2018, 09:26:01 PM
I can't remember off hand if the longer one fits in the 75, I'll take a look for you when I get home...
But until then I found this post where you don't even need to remove the esbit tray shelf, just bend the front down instead. Andy said he used both the 50mm and a 4.5"
https://www.tapatalk.com/groups/mode...ix+75#p1274588
There is also a guy in the UK that custom makes gas burners very reasonably and I've been happy with the ones I have from him.
Old 12-17-2018, 10:19:55 PM
Does this store on EBay look useful?
I think the 100mm aluminum burner will fit directly.
https://www.ebay.com/str/Green-Engin...1&_sop=1&_vc=1
Old 12-18-2018, 07:48:09 AM
There is also a guy in the UK that custom makes gas burners very reasonably and I've been happy with the ones I have from him.[/QUOTE]
Could I get the contact info for the UK burner builder?
Old 12-18-2018, 09:38:51 AM
Harry's Avatar
Images: 316
I don't know what the power out is from this is, but certainly enough for an incandescent light bulb.
(See our Terms of Service)
Old 12-18-2018, 10:13:27 AM
James Bosma's Avatar
James Bosma James Bosma is offline
https://www.pmmodelengines.com/shop/...amo-generator/
Here is a nice one
Buy as a kit or already to go
Old 01-08-2019, 12:14:04 PM
classixs classixs is offline
I agree completely with James above, you will not find a nicer dynamo than the PMR, especially when it comes to efficiency and pricing.
However, it does put a severe load on the engine, once it gets some bulbs hooked on, and i would think a #75 is pushing it, if one intends to use up the full potential of that dynamo?
Personally i would aim for a used Psantama Blue Thunder (or a Black Rhino), as recommended by Nick above, as they´re nice "plug´n´play" solutions.
As a very close second, and a 1st.in terms of pure output (the PMR aside), i would get one of the Austrian generators made by Kurt Berger.
They are very well made highly efficient (AC) generators, and comes with 3 different pulleys, which allow for quite a bit of versatility, in terms of which engines one wants to power them from.
He does ship worldwide, but will have to be messaged for a quote to the US.
https://www.ebay.de/itm/GENERATOR-An...e/163465820066
https://www.ebay.de/itm/GENERATOR-An...e/163472106814
Old 01-08-2019, 12:52:14 PM
Forgot about the Austrian genny's, have both the standalone and the wood-base with lamp-post, and like you said come with a nice selection of pulleys
Advice for steam engine design? Aristarchus Scale Model Engineering 2 11-14-2016 08:51:00 AM
High speed steam engine needs generator/dynamo and ID help willyjasper Steam Stationary Engines, Traction Engines 9 12-30-2015 06:23:14 PM
Homemade Scale Steam Engine Advice(pic included)) Trusty-Rusty-Tractor Steam Stationary Engines, Traction Engines 2 03-06-2014 11:53:11 AM
Need advice on steam engine piston Mike Shaffer Steam Stationary Engines, Traction Engines 5 09-03-2012 08:57:38 PM
New steam engine and need advice! Ricks1965 Steam Stationary Engines, Traction Engines 22 08-30-2011 01:14:55 AM
