Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
McCord force feed oiler disassembly and repair
this thread has 1 replies and has been viewed 492 times
Old 11-15-2018, 06:32:49 PM
con-rad con-rad is offline
Default McCord force feed oiler disassembly and repair
Hey all,
I had to take apart my McCord oiler to clean it and fix a stuck open check valve, and made a video of the process. Hope this helps out someone!
https://youtu.be/oDDeEw1Wn8c
One question I have though, out of pure curiosity. Where is the outlet check valve for the metering plunger (plunger closer to gooseneck dripper)? All the other checks are accessible except for that one.
connor
Old 11-16-2018, 06:12:11 PM
Default Re: McCord force feed oiler disassembly and repair
That check may be at the point where the oil line enters the engine. What does that line feed?
McCord Force Feed Oiler Cleanup Early Iron Oilers, Lubricators and Grease Cups 2 03-19-2017 06:47:00 AM
McCord Force Feed Lubricator Brian Nash Farm Antiques and Collectibles 1 01-10-2012 07:23:44 PM
How much pressure should a McCord force feed put out Temple2426 Vintage Diesel and Oil Stationary Engines 6 02-12-2010 08:50:15 PM
McCord oiler? Temple2426 Steam Stationary Engines, Traction Engines 4 08-08-2009 08:50:25 PM
Does anyone know anything about a McCord oiler? Temple2426 Vintage Diesel and Oil Stationary Engines 2 07-30-2009 03:35:17 PM
