Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
Madison Kipp OL lubricator
this thread has 0 replies and has been viewed 467 times
Old 01-10-2019, 02:36:32 PM
mrwalsh85 mrwalsh85 is offline
Default Madison Kipp OL lubricator
Hi All,
I've a NOS Madison Kipp OL lubricator that I would like to see about installing a ratcheting mechanism on. It does not have any type of actuating means so I'd like to see what I can pull off. It will probably eventually go on the market unless someone is interested in it as is.
The shaft has a woodruff keyway in it so I could use that as an option. However I have no way of securing the ratcheting motion to the shaft... I am considering using pointed setscrews, torqued down on the shaft, but I'm also considering drilling the shaft, which I believe is hardened. If I can drill the shaft, I can at least drill and tap it to accept a bolt to hold it in place.
Any suggestions would be appreciated.
Thanks,
Mike Walsh
St. Louis MO.
Madison Kipp Lubricator question Rumely Girl Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 11-16-2012 07:31:36 PM
Madison-Kipp Lubricator hatch Farm Antiques and Collectibles 4 10-10-2012 05:29:56 PM
Madison Kipp Lubricator Co. cams? RIRR Hit & Miss Gas Engine Discussion 13 03-09-2012 02:46:16 PM
Madison Kipp Lubricator KevinF Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 10-06-2009 04:55:53 PM
Madison-Kipp Lubricator Tom Wahl Antique Engine Archives 1 03-25-2001 10:29:55 PM
