Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Jensen Early Model Steam Engine
this thread has 2 replies and has been viewed 526 times
Old 01-16-2019, 08:41:42 PM
Steve Taylor Steve Taylor is offline
Default Jensen Early Model Steam Engine
Did Jensen make a model 10 that didn't have the lamp post? Wasn't sure if this lamp holder was original or replaced.
The Following User Says Thank You to Steve Taylor For This Post:
Old 01-18-2019, 01:24:54 PM
classixs classixs is offline
Default Re: Jensen Early Model Steam Engine
No, they didn´t...
If there´s no hole in the enginebase for a lamppost, your´s is the older pre-war version, that should have a standalone lamppost.
The early one´s had the lamppost sitting approximately where you now have a Wilesco lamp.
I don´t know if it still is the case, but one or two years ago, Jensen still had standalone lampposts in stock.
If it doesn´t show on their online partslist, i´d suggest that you give Dorita a call, and ask if they have any.
VERY nice looking engine
---------- Post added at 06:24:54 PM ---------- Previous post was at 06:11:49 PM ----------
...B.T.W.
By older, i am referring to the cast iron enginebase itself, as the plant is one of the later riveted boiler versions.
The Following User Says Thank You to classixs For This Post:
Old 01-26-2019, 10:48:56 PM
Junkologist's Avatar
Images: 160
Steve,
Your engine should have the stand alone lamp post where the bulb socket is now. There should be a hole in the base under the lamp socket and a sawcut channel on the bottom of the board where the wires to the original lamp post ran. Looks like a very nice engine you have there.
Mike
SmokStak member #146
What is it? Early Jensen Model 20? Len Spoelman Vintage Toy Steam Engines and Motors 22 01-13-2019 07:09:58 PM
2 Rare Early Odd Jensen Steam Engines - One You Might Not See Anywhere Else (except o Gil Garceau Vintage Toy Steam Engines and Motors 0 12-16-2018 10:56:59 PM
Jensen Mfg Steam Engine Model #20 Wanted jbfly Vintage Toy Steam Engines and Motors 1 11-24-2018 11:49:58 AM
Jensen Model 70 Steam Paul Spence Vintage Toy Steam Engines and Motors 2 09-24-2018 06:45:33 AM
Revisiting a 1930's Very Early Jensen Steam Engines Big Power Plant Gil Garceau Vintage Toy Steam Engines and Motors 1 12-22-2013 08:32:53 PM
