Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Jensen 75 retrofit with BIX 030 120mm burner
this thread has 7 replies and has been viewed 520 times
Old 01-27-2019, 08:08:55 PM
N0QBH N0QBH is offline
Default Jensen 75 retrofit with BIX 030 120mm burner
I recently purchased a BIX 030 burner kit with disposable type tank valve and a couple feet of small diameter copper tubing.
One end plumbed as an adjustable gas jet and finger tight connection to the tank valve on the other.
Getting the clearance to keep the boiler above the flame required removing the original fuel tray bottom and spreading the fuel tray sides apart as shown.
I had to cut away a 1/2" wide slot in the front of the firehouse to accommodate the burner mixer. A small Dremel drum sander made the semi circle bottom opening.
The material removed from the top of the firebox opening is unnecessary.
It's from an earlier, unsatisfactory attempt to fit the burner on the original fuel tray.
I'm happy to report the new configuration allows me to run the dynamo and LED street lamp very brightly, holding 17 psi like it was nothing.
Regards,
Mike
ID:	327298   Click image for larger version
ID:	327299   Click image for larger version
ID:	327300   Click image for larger version
The Following 2 Users Say Thank You to N0QBH For This Post:
Old 01-27-2019, 08:57:04 PM
Lester Bowman Lester Bowman is online now
Default Re: Jensen 75 retrofit with BIX 030 120mm burner
Be careful. Those gas burners get hot enough to melt soft solder even with water on the other side. Keep it on low.
Old 01-27-2019, 09:10:42 PM
Junkologist's Avatar
Images: 160
No worries, Lester. All Jensen boilers beyond the riveted era are silver soldered. Iíve picked up engines in the past with boilers that were blue from dry heating and suffered no damage.
Mike
SmokStak member #146
The Following 2 Users Say Thank You to Junkologist For This Post:
Old 01-28-2019, 01:14:12 PM
Mission accomplished - Heat to Light with a Jensen 75 and Buehler motor/generator.
Thanks to the SmokStak input along the way.
ID:	327354   Click image for larger version
ID:	327355   Click image for larger version
The Following User Says Thank You to N0QBH For This Post:
Old 01-28-2019, 05:20:22 PM
Nick Severson Nick Severson is offline
Nice work, but now we want a video
The Following User Says Thank You to Nick Severson For This Post:
Old 02-01-2019, 12:42:58 PM
Ringo Lake Power & Light
---------- Post added at 10:42:58 AM ---------- Previous post was at 10:41:03 AM ----------
It seems my attempt to upload a video failed...
Old 02-01-2019, 05:34:10 PM
Ringo Lake Power & Light video
Old 02-01-2019, 05:50:57 PM
You want just this short bunch of letters after the forward slash between the YOUTUBE writing: stWkkgAivVw
https://www.youtube.com/watch?v=stWkkgAivVw
Onan CCK oil filter retrofit marvgarr Onan Generators 7 12-31-2012 06:39:50 AM
Jensen #75 meth alcohol burner Woody Sins Vintage Toy Steam Engines and Motors 15 10-31-2012 12:48:16 PM
125.0 DYD electronic governor retrofit Isaac-1 Onan Generators 15 09-21-2010 07:01:51 PM
C859 - replace or retrofit? Tom_S Onan Generators 0 05-15-2006 05:20:19 PM
Help with onan engine retrofit ChrisR Onan Generators 4 02-17-2006 02:39:49 AM
