Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Unknown Toy Electric Motor. Help Identify!
this thread has 17 replies and has been viewed 874 times
Old 01-28-2019, 10:00:26 PM
watt watt is offline
Default Unknown Toy Electric Motor. Help Identify!
This came to me in the bottom of a box of "stuff". What is it?
ID:	327400   Click image for larger version
ID:	327401   Click image for larger version
The Following 2 Users Say Thank You to watt For This Post:
Old 01-28-2019, 11:40:10 PM
Heins Heins is offline
Default Re: Unknown Toy Electric Motor. Help Identify!
I think it is an electric motor, the coils of wire would magnetize the part that the wire is wound around. The cam on the shaft would turn the electricity on and off so the coils would work.
Old 01-29-2019, 12:36:07 AM
ulgydog56's Avatar
I think heins is on the money, early electric motor, no osha back then...lol..mite be a deminstraitor model..
Old 01-29-2019, 06:41:50 AM
Junkologist's Avatar
Images: 160
You have an H-K (Hawekotte & Klausmann) toy electric motor. They made many styles of these magnetic impulse motors in the early 1900s.
Mike
SmokStak member #146
The Following 4 Users Say Thank You to Junkologist For This Post:
Old 01-29-2019, 07:47:26 PM
Thanks, everyone, especially Junkologist. I did a bit of poking around on the Internet , and H-K really does seem to fill the bill.
Old 01-29-2019, 09:52:36 PM
Images: 160
Here’s a similar one I have that still has the paper label on the bottom.
ID:	327511   Click image for larger version
Mike
Old 01-30-2019, 01:49:41 AM
Wow! Nice!
I'm wodering if there's a way to repair the base of mine--and no, I don't have the broken-off piece.
Old 01-30-2019, 08:06:31 AM
Images: 160
Repairing your base without the missing piece will be tough. Your best bet would be to watch eBay for another motor like yours that may be in rough shape with a complete base. That way, you could get the part you need at a reasonable price and not feel bad for dismantling another motor. If I see one like yours on eBay, I’ll let you know. I search daily for this stuff.
Mike
Old 01-30-2019, 11:10:26 PM
Default
Thanks, Junkologist. Every bit helps.
Old 01-31-2019, 01:49:10 AM
Motormowers's Avatar
Originally Posted by watt View Post
Wow! Nice!
I've seen a few guys on Youtube repair broken Matchbox chassis with super glue and baking powder. It dries instantly and you can build it up and file it to shape then paint the base. Its hard as a rock.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
The Following User Says Thank You to Motormowers For This Post:
Old 01-31-2019, 09:30:25 AM
Might be worth a try. Can't hurt, anyway.
I'd also been thinking of JB Weld.
Old 01-31-2019, 10:03:46 AM
Lester Bowman Lester Bowman is offline
Just Remember Watt..any kind of "repair" you do to it won't add a cent of value and will probably diminish what value it already has. A donor motor with a good base would of course be perfect. But repair? I wouldn't. Leave it as is. It is sharing a story and its life with its present condition
The Following User Says Thank You to Lester Bowman For This Post:
Old 01-31-2019, 10:15:56 AM
A very good point, indeed. And of course it's easier to do nothing, isn't it?
Old 02-01-2019, 04:15:07 PM
Sometimes NOT doing anything leaves more of the history than "doing something". It's your motor. Do what you want with it.
Old 02-01-2019, 06:55:51 PM
Power Power is offline
If I wanted to run it, I would glue a shim under the broken section.
Then I could enjoy it while leaving it unaltered. Shim could be easily removed with no damage.
If just for display, probably leave it alone.
Old 02-02-2019, 01:19:59 PM
Thr consensus here seems to be "If it's broke, don't fix it." Think I'll go along with that.
Now I'll have to check out the wiring and see if it'll run.
6 volts?
Old 02-02-2019, 03:33:37 PM
Images: 160
1-1/2 volts should make it go. Try a D cell.
Mike
Old 02-02-2019, 04:00:12 PM
'Kay. Thanks.
Old electric motor metalist Generators & Electric Motors General Discussion 2 03-04-2016 08:50:32 PM
Help identifying unknown electric motor forney00c Generators & Electric Motors General Discussion 4 08-29-2015 08:21:36 AM
Electric DC Motor Toy can anybody identify what it is Randy L Peterson Vintage Toy Steam Engines and Motors 5 01-19-2012 11:41:53 PM
Help with electric motor? aburton Vintage Toy Steam Engines and Motors 2 12-20-2009 01:33:09 AM
Electric Motor Dominick Generators & Electric Motors General Discussion 0 01-26-2004 02:39:38 PM
