Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Steam Model – No name - found
this thread has 5 replies and has been viewed 652 times
Old 02-03-2019, 11:24:19 PM
Default Steam Model – No name - found
at the “FLEA” market. As soon as I got there, I was told Ryan has one (already sold and gone). Then awhile later, a friend on the way out saw me and said there is a Steam Model over here and he showed me where. I asked, and it was the one Ryan had, I could have it (resale) for X $’s . It looked like it had a tough life, all taped up, but complete . We negotiated a bit on price, and I came away with the no name, electrically heated steam engine. After I got home, I oiled it up good with PB Blaster, got it loose, added some air, and away it went - sounds good. removed the black sticky tape all over it, got it partially apart, freed up the whistle, and ran out of time. Any body know what make this Steam Engine with its tin base, nickel plated copper boiler, feed water-pressure relief through the stack, missing the threaded steam control valve could be . What a way to end the day, by just having fun , even in NJ .
Name:	Steam 2-3-19 (1).jpg
ID:	327891   Click image for larger version
Name:	Steam 2-3-19 (2).jpg
ID:	327892   Click image for larger version
Name:	Steam 2-3-19 (3).jpg
ID:	327893   Click image for larger version
Name:	Steam 2-3-19 (4).jpg
ID:	327894   Click image for larger version
Name:	Steam 2-3-19 (5).jpg
ID:	327895   Click image for larger version
Name:	Steam 2-3-19 (6).jpg
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 02-04-2019, 12:01:12 AM
ulgydog56's Avatar
Talking Re: Steam Model – No name - found
had one in the late 1960's as a kid it is was similar design, not electric thu, it was made in germany like most toy steam engines, good luck...
Old 02-04-2019, 12:23:41 AM
Junkologist's Avatar
Default Re: Steam Model – No name - found
Paul,
You have an Empire model 43 steam engine made by The Metal Ware Corp in Two Rivers, WI. Look close on the underside of the base, the name may be stamped there. These are fairly common, but still a nice find. You are missing the steam throttle and the handle to actuate the whistle.
Mike
SmokStak member #146
Old 02-04-2019, 07:59:42 PM
Mike: I cleaned the dirt off the heater cover and found the stamped information on my Empire 43. Now to find, or make the missing parts if I can find a drawing for them. Thanks-Paul
Old 02-04-2019, 10:25:45 PM
I wish I could give you the info to make the missing parts, but I don’t have an Empire 43. You may be able to find a parts engine on eBay for a reasonable price, if you’re lucky.
Mike
Old 02-14-2019, 08:13:51 PM
Ohio Farm Ohio Farm is offline
You are missing the steam throttle control screw. On my Empire 43 it's a brass 8-32 screw about 1-1/8 inch long. Tt's just slightly beveled on the steam end, and has a bakelite knob with locknut on the other. I made one for another Empire I have, and the knob is available at any hardware store.
Steam model found, needs a makers Paul Spence Hit & Miss Gas Engine Discussion 6 04-01-2016 07:27:53 AM
Steam engine found Mbetti Steam Stationary Engines, Traction Engines 45 06-17-2015 08:53:49 PM
Burrell Showman Model Steam Engine stolen (found) from the NEWSM m_thompson Steam Stationary Engines, Traction Engines 16 03-17-2015 10:09:09 PM
FOUND: Unknown Make, Model Steam Engine and Boiler Robert Bruce Steam Stationary Engines, Traction Engines 3 02-13-2010 03:40:49 PM
Steam Engine Cut-away Found Paul Spence Steam Stationary Engines, Traction Engines 0 05-22-2003 01:04:49 PM
