Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Meccano - STEAM - Ferris Wheel
this thread has 16 replies and has been viewed 951 times
Old 02-12-2019, 03:40:39 PM
Default Meccano - STEAM - Ferris Wheel
While walking down one of the undisclosed ďFLEAĒ market aisles this past weekend, looking for "STUFF", I spotted this model Ferris wheel , that has a 110 volt Wasp electric geared motor with the reversible transmission and twin-3 grove pulleys on it. I did a quick look over, the unit spun freely, and asked how much? I just gave the guy his asking price of $10 . It is a nice piece (a bit dusty and neglected), 17+Ē in diameter, wired with light sockets for eight GE52 12-volt bulbs (only one left) wired in series, and the commutator for the 110-volt electric lighting wiring attached (sparky you say, of course ). There are no makers name on it, and the internet search began. After a bit of research (minutes turn into hours ), I think itís a pre 1964 MECCANO Erector set built unit with the early ELEKTRIKIT 120 volt wiring for the lights. The WASP motor runs and the transmission works, forward and reverse. Iím looking for some inexpensive GE 52 bulbs (must be rare), and I need to make up a drive belt to test it out. Just another project in ďQĒ, taking up work bench space. In the future (sometime), Iíll probably go with a low voltage, battery set up for the lighting (just a bit safer), and may run it off a steam engine model with a generator, or ÖÖ.. something. Your thoughts are welcome, and Iím just having ďFUNĒ, even in NJ on the way through on a crummy weather day.
ID:	328532   Click image for larger version
ID:	328533   Click image for larger version
ID:	328534   Click image for larger version
ID:	328535   Click image for larger version
ID:	328536   Click image for larger version
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 02-12-2019, 11:23:30 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Re: Meccano - STEAM - Ferris Wheel
Paul, nice find. 🎡 Look really cool running off a model engine. I gotta find that flea market! 🤔. The real NJ secret. 🤫. Good luck, thanks for sharing.
Old 02-13-2019, 07:11:25 AM
pauljac pauljac is offline
There are some GE52 bulbs on e-bay. A 10 pack for $25. Yes, they are 12 V. Good luck!
Old 02-13-2019, 12:40:35 PM
John Newman, Jr.'s Avatar
Would very old style Christmas light bulbs fit?
Name:	Christmas Lights 01.jpg
ID:	328616   Click image for larger version
Name:	Christmas Lights 02.jpg
ID:	328617   Click image for larger version
Name:	Christmas Lights 03.jpg
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 02-13-2019, 04:06:42 PM
Found the GE52 12volt bulbs at McMaster Carr. 10 for $6.95, brand new. They will be here tomorrow . Sure beats the price for the 12 volt ones on eBay . Working on getting 1/8" drive belts for the drive . Sure am having "FUN", even in NJ, on the way through .
Old 02-13-2019, 04:30:18 PM
Paul, do the belts have to be rubber? maybe some leather shoelace from an old boot mated by thin staple might do the trick unless your giving the kids a ride.
Old 02-13-2019, 05:11:02 PM
N0QBH N0QBH is offline
I bought 10' of O-ring stock for well under $10.
Cut to length with an eXacto knife, a tiny drop of superglue on one end and make a butt joint.
Way less stretch than springs.
Old 02-14-2019, 08:41:51 PM
Couldn't get my hands quickly on some "O" ring stock , so I pulled out a piece of plastic, storm window spline and made a temporary drive belt . Works OK for a little while just so I can get some "action", (counter clockwise & clockwise) out of it. The GE52 bulbs are on the way for the lighting. Here is the first video of the Ferris Wheel in motion . Just might set it up (sometime) with one of my steam engine models for a different look. Just having "FUN" with a new toy, even in NJ on the way through .
Old 02-14-2019, 09:43:18 PM
Junkologist's Avatar
Iíve never had much luck with super glue and o-ring stock for belts. The joint always fails. What Iíve found to work perfectly for model belts, is rubber cord used for crafts. Itís super cheap and the ends can be joined by welding. Just heat, melt and join the ends. The 2mm size is nice for model steam engines.
Mike
SmokStak member #146
Old 02-15-2019, 08:03:36 AM
Hobby Lobby is on my "stop for stuff" list today. THANKS
Old 02-16-2019, 10:30:31 PM
Hobby Lobby wasnít any help, but when I got home, I took Mikeís suggestion and just welded (heated the cord ends with a match and fused them together-works for me). I cleaned the bulb sockets with some fine steel wool, and put the GE52 bulbs in, and then carefully plugged them in to 110 volts in anticipation of the worst. All I got was some erratic lighting , and with a small contact adjustment of the wiper fingers on the commutator, all is well . Here is a video of the Lighted FERRIS WHEEL in operation , and even when reversed. Now that thatís done, I need to work on getting some gondolas made for it, and finding some appropriately sized figures, or whatever to put in them . Sure am having ďFUNĒ, even in NJ on the way through.
Old 02-16-2019, 11:05:28 PM
Paul, that is a cool project your tinkering with. Is that the asbury park wheel? Lol. I havenít been there since 82í. Iím sure the Ferris wheel is gone by now.
Old 02-17-2019, 07:47:46 AM
Shawn: The Ferris wheel was destroyed in the "SANDY" storm, and this could be a model of it built way back then . Off to the "flea" market on a cold Sunday AM, for "stuff" .
Old 02-20-2019, 10:29:00 PM
Since the WASP drive motor had a 3 step pulley I made up two more drive belts out of the plastic storm window spline I had, cut and welded (with a flame ) and now I have a slower running , 3 speed Ferris wheel. I picked up 6 - 1/4" x 3" standoffs (McMaster Carr) to put between the "wheels" as I work on the gondola design (need more "stuff"), while pushing heavy snow off the vehicles and down the driveway. Did I say I'm having "FUN" even in NJ today, on the way through .
Old 02-21-2019, 05:57:02 AM
georgineer georgineer is offline
Paul,
Nice find, but I'm not convinced that it's made of Meccano. In the pictures I see pan-head screws and hex nuts, whereas Meccano used cheese-head screws and square nuts. The Meccano thread was 5/32" BSW (British Standard Whitworth).
Also, the slotted discs at the hub and the die-cast pulley wheel aren't like any Meccano parts I've ever seen. My guess is that it is some other kit inspired by Meccano.
George
Old 02-21-2019, 08:33:27 AM
George: Thanks for the input . The screws are 8-32's , and the slotted discs (similar to), but only have single holes where the Meccano have two . I do like the slip rings for the lighting . It may be just built from Gilbert Erector set parts, but I'm having "FUN" with it .
Old 03-02-2019, 01:27:35 PM
gadgetconsumer gadgetconsumer is offline
I was poking around on the internet and found 2.4mm rubber cord available at Grainger, Amazon and other sources by manufactured by E. James. Do you think 2.4mm is fine for general use as my standard spring belts from Wilesco lack the grip for some applications.
Mamod/Meccano SP3 Restoration Fishplate42 Vintage Toy Steam Engines and Motors 18 10-16-2013 03:31:08 PM
Meccano - Some of my recent models Fishplate42 Vintage Toy Steam Engines and Motors 0 09-03-2013 02:04:19 PM
Meccano and Marklin Engines chenab Vintage Toy Steam Engines and Motors 0 03-14-2012 12:44:16 PM
Meccano/Erector Triple Expansion Engine joeburgard540 Scale Model Engineering 0 02-08-2009 11:48:10 PM
Grant-Ferris Richard Durgee Antique Engine Archives 0 07-17-2003 12:48:08 PM
