Go Back   SmokStak > Other Vintage and Antique Collectibles > Antiques for the Home > Vintage Toy Steam Engines and Motors
Vintage Toy Steam Engines and Motors Weeden, Empire, Doll, Jensen, Wilesco, Mamod, Marklin
Adding a Boiler Feed Pump?
this thread has 1 replies and has been viewed 296 times
Old 05-16-2019, 10:35:30 PM
Spenser Rynne Spenser Rynne is offline
Default Adding a Boiler Feed Pump?
Hello, all. Working on some displays for the up and coming show season, and decided to rig up a generator to run a few of my old steamers. Currently a Jensen and an old Empire B-30, both electric heat engines. I have a Weilsco D-21 on a large table top setup, which was fitted with a gas burner and came from the factory with a boiler hand pump.
Frankly, I prefer my older engines over the Weilsco, since for one, it isn't old. And it just doesn't run as nice as the others. Also, it doesn't fire well outdoors.
Anyway, what I think I'd like to do is set up a feed pump on at least one of the older engines. The Empire even has a blanked off fitting that I think could be used for a water line. I'm more of a gas engine person and not too awful schooled on steam. A search online so far has brought back nothing. Weilsco doesn't sell a separate pump, even as parts, for my engine. If I had provisions, I'd machine one myself.
Has anyone ever done such a thing?
Old 05-19-2019, 05:52:42 AM
fredrosse fredrosse is offline
Default Re: Adding a Boiler Feed Pump?
Fairly easy to make a feed pump with a small stainless steel pneumatic cylinder as a starting point. These are often available on ebay for just a few dollars. Suction and discharge check valves are needed, I have often made them from 1/8 inch pipe fittings, with a 1/4 inch diameter ball, held in place with a light spring (ballpoint pen size approx.) against a compression fitting. See what you may cobble together, takes me about 2 hours plus some readily available brass fittings to make the pump.
Steel balls are available from various bearings, but if you want long life, get stainless balls, or teflon balls. Wind your springs from brass or bronze or stainless wire, or
Adding a Feed PUMP to a Toy Steam Engine Spenser Rynne Scale Model Engineering 4 05-22-2019 06:22:44 AM
Miller Co Boiler feed pump JIM MODEL 110 Steam Stationary Engines, Traction Engines 1 02-27-2017 10:47:42 PM
Stuart Boiler Feed Pump Big Bird Scale Model Engineering 4 07-02-2016 02:49:14 PM
boiler feed pump question Big Bird Scale Model Engineering 4 02-03-2015 10:38:39 AM
Boiler feed pump for models Casemaker Steam Stationary Engines, Traction Engines 13 07-25-2007 10:23:13 PM
