Cushman Model 21 Type X- Carburetor
this thread has 2 replies and has been viewed 234 times
Old 05-21-2019, 03:27:27 PM
KubotaDiesel KubotaDiesel is offline
Default Cushman Model 21 Type X- Carburetor
Hey guys and gals. My Cushman X has a carb from a Cushman Cub on it. (Smooth). It will not run with is, it only tries to chug about 3-4 revolutions. I'm needing help (I've tried about everything I can think of) or I need an original carb for a Cushman Model 21 Type X. Any input or help would be much appreciated! Thank you. -Derek
Old 05-22-2019, 09:14:01 AM
Turbo's Avatar
Turbo Turbo is offline
Default Re: Cushman Model 21 Type X- Carburetor
Having owned both I would think the cub carb would work just fine on an X. They are very similar. I think you should re-check the usual things; Spark, timing, fuel check valve, etc. Try covering part of the carb intake with tape to act as a choke. Possible bad gas? Bad spark plug?
Old 05-22-2019, 09:29:10 AM
Thank you turbo. I was leaning towards the carb. I'm using an antique plug though I will say I've usually always had good luck with. I'll mention that the throttle shaft is awful worn though and the carb leaks fuel everywhere. The check valve I'm using is that of another old engine and it is good. Timing is on the mark though compression isn't quite what I'd like. The valves seat well from what I'm seeing and the mag I'm using is very hot. This old engine has been my nemesis.
Cushman 3HP Model BB, Type H Joel Mosley Hit & Miss Gas Engine Discussion 13 07-07-2019 05:25:09 PM
Cushman Model 25 Type WH George Zink Hit & Miss Gas Engine Discussion 27 12-13-2013 10:40:59 PM
Cushman Model 21 type X Tom Sampson YouTube Old Iron Videos 11 01-13-2012 12:08:13 PM
Cushman, 1 1/2 hp, type X, Model 21 John E Perry Hit & Miss Gas Engine Discussion 0 04-15-2007 11:32:09 AM
Cushman Model BB Type V. HP 5 21avery Hit & Miss Gas Engine Discussion 1 01-18-2005 09:10:30 PM
