Go Back   SmokStak > SmokStak® Antique Engine Community > Oilers, Lubricators and Grease Cups
Oilers, Lubricators and Grease Cups Discussion about collecting and restoring oilers, lubricators & grease cups.
Powells's Pressure Sealed Lubricator
this thread has 4 replies and has been viewed 416 times
Old 06-18-2019, 10:40:29 AM
IronworkerFXR IronworkerFXR is offline
Images: 50
Default Powells's Pressure Sealed Lubricator
How the heck do you get this appart , stuck tight .
Old 06-18-2019, 10:43:59 AM
Ellis Wellman Ellis Wellman is offline
Default Re: Powells's pressure sealed lubricator.
That is a very old Powell.Try not to take it apart.They can usually be cleaned for use .
The Following User Says Thank You to Ellis Wellman For This Post:
Old 06-18-2019, 03:25:40 PM
K-Tron K-Tron is offline
An ultrasonic cleaner will make that lubricator spotless inside and out without any further disassembly.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 06-18-2019, 10:45:30 PM
Greg Mosley Greg Mosley is offline
Default Re: Powells's Pressure Sealed Lubricator
Greetings Ironworker, Heed K-Tron and Ellis advice. The oiler you have in your possession is an early Powell Oiler and a difficult one to find indeed. I have only have come across a handful in many years. I searched along time for one when on the hunt. Does it have any data on the opposite side?? Good Luck. Enuf Said.
Old 06-19-2019, 01:17:21 AM
Images: 50
Thank you gentlemen for the advice, I wanted to put it on my Bovaird & Seyfang , when I got it the vent tube was off inside .
so I wanted to fix that as if you put oil in it it just pour out.
they must of soldered the upper reservoir to the dripper assembly . I plan to keep it in the work clothing , got some glass, will post more. no date on it about what year ?.
John
The Following User Says Thank You to IronworkerFXR For This Post:
Sealed Bearings Geochurchi Machine Shop and Tool Talk 2 11-26-2018 11:25:36 AM
How do you test force feed lubricator pressure primerk5 Steam Stationary Engines, Traction Engines 8 05-08-2013 08:43:23 PM
Charging Sealed Batteries Horse Power at 511 Magnetos, Ignition Coils and Spark Plugs 7 01-20-2010 11:42:59 PM
Detroit three feed pressure lubricator tim moisio Antique Engine Archives 1 05-16-2002 08:15:53 PM
Powells Books on Harry's Harry Antique Engine Archives 2 01-06-2002 03:30:08 PM
