Briggs and Stratton ZZ Weak Magnets
this thread has 7 replies and has been viewed 554 times
Old 06-20-2019, 04:34:21 PM
pigpen60 pigpen60 is offline
Default Briggs and Stratton ZZ Weak Magnets
I have a Briggs ZZ engine on a GI generator and I was told by the fella that gave it to me it needed a new capacitor. I replaced the capacitor and cleaned the points and while I was in there I noticed the magnets on the flywheel are very weak. After reassembly I grabbed the plug wire and spun the wheel and I could just feel a tick instead of a normal jolt. So after all this am I going to have to find a new flywheel? TIA
Old 06-21-2019, 11:10:51 AM
Default Re: Briggs and Stratton ZZ Weak Magnets
Could a moderator please move this to the small air cooled gas engine area?
The Following User Says Thank You to pigpen60 For This Post:
Old 06-21-2019, 12:41:35 PM
Vanman Vanman is offline
I would imagine that the magnets could be remagnetized if need be, as with other magnetos.
Old 06-21-2019, 03:45:57 PM
A good magneto shop should be able to re-charge your flywheel. Be sure to send it with a keeper (piece of steel) across the magnets, to keep the magnets up
Old 06-21-2019, 10:12:27 PM
K-Tron K-Tron is offline
You might need a lot more than just a magnet charge. The coils in those engines often go bad at there age, and finding one in NOS condition is a crapshoot. There are a couple of guys who re-wind new coils for your particular engine, but they are not cheap. If your coil is bad, you are looking at $150 for a replacement coil.
Chris
Old 06-23-2019, 06:05:48 PM
Pulled a flywheel off another genny I have and the magnets where/are a little stronger. Installed on the genny I'm working on and I got a better jolt but not what I'm used to on a running engine. So let me understand this, if I pull a flywheel off I need to put a piece of steel on the magnets to prevent them losing their pull?
Old 06-23-2019, 07:18:35 PM
I am not sure where Andrew gathered that piece of information about the flywheel magnets. Briggs & Stratton, Tecumseh, Lauson, Clinton, Power Products, etc, etc did not ship brand new flywheels with any form of steel covering the magnets. As long as you do not put your flywheel next to an electromagnet you will be okay. I have picked up some ZZ's that were in pieces for decades, and neither need a magnet charge.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 06-23-2019, 08:52:10 PM
gdstew gdstew is offline
The NOS Eiseman and Bendix magnetic rotors I have came with a piece of steel around them. That's the way they were in the day. Never saw a flywheel with one and I had a bunch of NOS flywheels just as old.
Briggs and Stratton 8B Weak Ignition Zen Small Air Cooled Gasoline Engines 23 12-08-2013 12:38:44 AM
Maytag 72D with Weak Magnets, Spark Loghaus Maytag Engines and Collectibles 4 11-27-2008 10:45:45 AM
Bultaco M/C Magneto magnets weak? Karl T Schwab Magnetos, Ignition Coils and Spark Plugs 4 05-26-2006 10:21:01 PM
weak magnets Arthur Antique Engine Archives 8 07-24-2004 02:28:11 PM
weak magnets Lester Bowman Antique Engine Archives 0 08-17-2003 11:44:38 PM
