Odd Gas Tank
this thread has 3 replies and has been viewed 440 times
Old 06-24-2019, 01:56:06 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo Odd Gas Tank
Never seen a tank like this, obviously it mounts flat against something, engine? tractor? Its 9-1/2" diameter.
Patrick
ID:	337794   Click image for larger version
ID:	337795   Click image for larger version
ID:	337796   Click image for larger version
ID:	337797   Click image for larger version
The Following 2 Users Say Thank You to Nevr-Enuf-Stuf For This Post:
Old 06-24-2019, 02:15:15 PM
pauljac pauljac is offline
Default Re: Odd Gas Tank
This style tank attached to the back of the seat of a Go-Kart.
The Following 2 Users Say Thank You to pauljac For This Post:
Old 06-24-2019, 02:30:31 PM
gdstew gdstew is offline
pauljac got it!
The Following 2 Users Say Thank You to gdstew For This Post:
Old 06-24-2019, 10:29:30 PM
GADavis GADavis is offline
That style of tank was used on lot of early racing Go Karts. It was mounted to the seat back in front of the engine.
---------- Post added at 10:29:30 PM ---------- Previous post was at 10:26:48 PM ----------
Early style fuel tank for use on a racing Go Kart. It was mounted on the seat back in front of the engines. Usually held about 1/2 gallon or so.
The Following User Says Thank You to GADavis For This Post:
Galloway in UK - Tank cooled, fuel tank position? Neale Pryce-Hughes Antique Gas Engine Discussion 4 06-28-2016 10:22:37 AM
Fuel tank - desolder tank halves to repair? KD5BYB Small Air Cooled Gasoline Engines 8 12-04-2011 06:08:58 PM
"Spraying" in Red-Kote tank liner into unremovable tank. Anyone tried this? YZ1 Paint Shop 8 08-03-2010 06:35:26 PM
Tank sealer in a installed tank Gilbert_Bates Antique Gas Engine Discussion 10 07-21-2008 08:40:02 PM
