6B-HS Points?
this thread has 4 replies and has been viewed 344 times
Old 06-27-2019, 10:09:05 PM
Leroy Leroy is offline
Default 6B-HS Points?
In replacing the points and condenser in my lawnmower engine I noticed the points will not move upon rotating the blade . I seem to be able to rock the plunger slightly but no in and out movement that opens and closes the points . What could be stuck ? No access from the top for this .
The Following User Says Thank You to Leroy For This Post:
Old 06-27-2019, 10:26:57 PM
GADavis GADavis is offline
Default Re: 6B-HS Points ?
Plunger is worn off at the end. One upon a time, a new plunger came with each set of points and condenser.
Old 06-28-2019, 01:04:08 AM
Gee , never got that in my re new kit . Yes its apparently stuck maybe in the out position . Its like bakelite plastic . Brittle when pressure applied .
Old 06-28-2019, 02:02:39 AM
Default Re: 6B-HS Points?
The plunger will break if you get rough with it. Always good to have extra parts or a whole parts engine.
Old 06-28-2019, 02:29:53 AM
Tom Schaech Tom Schaech is offline
Plunger part number 65704. Your local Briggs dealer should have them. Old part number for complete ign kit with plunger and plastic compression tool for condenser spring #299061
The Following User Says Thank You to Tom Schaech For This Post:
EmeraldPlus 4BGEFA26100K Points or No Points whitlow Onan Generators 2 10-27-2018 10:05:34 PM
Onan 6.5nh Points Problem and Points Replacement and Adjustment mvimpvm Onan Generators 18 11-28-2017 12:11:05 PM
Points Gap Cruiser Onan Generators 1 10-17-2010 12:28:59 PM
Points Gap George Vaughan Hit & Miss Gas Engine Discussion 1 06-26-2005 08:35:08 AM
