Briggs Valve Sizes
this thread has 1 replies and has been viewed 318 times
Old 07-03-2019, 10:22:06 PM
K-Tron K-Tron is offline
Default Briggs Valve Sizes
I was wondering if Briggs & Stratton ever released any information on valve dimensions for their engines?
I am looking for a valve 0.248" stem size, 3.435" long with a head diameter of 0.905", which accepts a pin type keeper 2-7/8" from the head of the valve. The valve I am looking for from memory looks similar if not identical to what a model 8 Briggs & Stratton uses. Does anyone have a model 8 Briggs on the bench that could send me some valve dimensions? I can shorten, turn down and cross-drill a valve of slightly larger dimensions if I could find one for my project. Thanks,
Chris
Old 07-03-2019, 10:48:33 PM
ArodaPowerCo ArodaPowerCo is offline
Default Re: Briggs Valve Sizes
Another avenue if you are willing to modify a valve. Ream your guide to 7mm and that will open up a plethora of options in metric automotive valves to be had free or cheap. Find your local automotive machine shop. They will ream your guide and likely have scrap valves laying around to pick through. All you'd need to do would be cut down and drill for the pin as needed.
What is your project?
Edit: Kohler V-twin valves are 7mm also.
Briggs 2 HP Valve clearance frontier52 Small Air Cooled Gasoline Engines 2 12-02-2015 10:54:09 AM
PCV Poppet Valve on Briggs WI KSKRUSER Small Air Cooled Gasoline Engines 2 01-03-2015 08:47:44 PM
Witte 2 HP throttle governed valve sizes bartlett0815 Hit & Miss Gas Engine Discussion 0 09-21-2013 09:25:37 PM
Briggs NS Valve Springs? WaterlooBoy2HP Small Air Cooled Gasoline Engines 5 04-09-2012 05:40:08 PM
Briggs valve seat Chris Kirk Antique Engine Archives 7 02-11-2003 01:11:50 PM
