Briggs ZZ Engine Questions
this thread has 2 replies and has been viewed 394 times
Old 07-07-2019, 12:14:58 AM
pigpen60 pigpen60 is offline
Default Briggs ZZ Engine Questions
What kind of plug wire would be on this engine? The engine is on a military genertor so I have one with the shielded ignition and the other has a normal civy style. I was looking in the book for the zz and it showed clutches for this engine, anyone have one on their engine?
The Following User Says Thank You to pigpen60 For This Post:
Old 07-07-2019, 04:57:36 PM
Arlie Levy Arlie Levy is offline
Default Re: briggs ZZ engine questions
this would use a copper core wire.
The Following User Says Thank You to Arlie Levy For This Post:
Old 07-10-2019, 12:20:51 AM
Default Re: Briggs ZZ Engine Questions
Went to a little place called Tractor Supply not to be confused with TSC and found my plug wire. I love that place! Its packed but if you ask for help they will likely find what you need. Oh and they are in Moscow Mills Missouri.
The Following 2 Users Say Thank You to pigpen60 For This Post:
Briggs and Stratton engine restoration questions Wd40 Small Air Cooled Gasoline Engines 1 12-29-2014 01:44:44 PM
Briggs 3hp Questions? Railroads Small Air Cooled Gasoline Engines 3 03-20-2014 01:06:30 AM
Briggs Questions Pat Barrett Small Air Cooled Gasoline Engines 6 04-24-2011 06:37:11 PM
Briggs snowthrower engine model 130202 questions andy b. Small Air Cooled Gasoline Engines 13 07-21-2010 06:36:42 PM
Questions on a briggs 8hp engine oncewaslost1982 Garden Tractors and Mowers 4 05-16-2007 09:23:22 PM
