Briggs model 19 help
this thread has 5 replies and has been viewed 538 times
Old 07-08-2019, 10:29:59 AM
Walt Beeman's Avatar
Walt Beeman Walt Beeman is offline
Default Briggs model 19 help
I have a model 19 on a Simplicity 2 wheel tractor. I rescued it from a scrap pile, it was left uncovered for years. As a result I need a flywheel shroud and back plate. I would also like to know if the flywheel nut is right or left hand thread. Many thanks for any help.
UPDATE, I have found a back plate and flywheel shroud, but I still would like to know about the thread on flywheel nut.
Keep Enjoying Old Iron,
Walt Beeman
Old 07-09-2019, 02:15:24 AM
Default Re: Briggs model 19 help
The nut holding the flywheel has right hand threads, so you turn it counter clockwise to remove it.
The Following User Says Thank You to EvilDr235 For This Post:
Old 07-10-2019, 03:22:41 PM
I managed to remove the flywheel, now I'm trying to figure out the removal of the coil assembly. I removed the three bolts on it, but it doesn't move. Is it just stuck or is there something else that I am missing? This model has the coil underneath the flywheel.Due to cancer I am legally blind and really appreciate any help.
Walt Beeman
Old 07-28-2019, 07:40:48 AM
UPDATE, I won, the coil mount required "gentle" encouragement with a brass drift and hammer, No Damage. Engine runs beautifully. Thanks for all who assisted.
Walt Beeman
The Following 2 Users Say Thank You to Walt Beeman For This Post:
Old 07-29-2019, 10:48:15 AM
pigpen60 pigpen60 is offline
Any pictures?
Old 07-29-2019, 12:16:25 PM
Pictures please.
Briggs 5s, 6s, model N and model 8 flywheels and related models. EvilDr235 Small Air Cooled Gasoline Engines 1 04-20-2019 09:53:52 PM
Briggs ID What Year Model and hp is my Friends Briggs Cml4fun Small Air Cooled Gasoline Engines 6 07-21-2018 11:25:29 PM
Briggs Model K or Model Q with Clutch Question NAR Small Air Cooled Gasoline Engines 4 06-07-2018 09:47:58 PM
Agricat Model F Crawler w/Briggs Model 23 Bonden Small Air Cooled Gasoline Engines 9 12-09-2014 12:05:53 AM
Briggs Model PB Crank (For Moto-Mower Detroit Model) Jonathan Widelo Small Air Cooled Gasoline Engines 0 02-05-2009 02:43:17 PM
