Briggs and Stratton model A - oil cup on hand crank
this thread has 5 replies and has been viewed 332 times
Old 07-11-2019, 10:33:19 AM
CaptAndy CaptAndy is offline
Default Briggs and Stratton model A - oil cup on hand crank
Looking to see how to remove the "cup,oil" on a hand crank model A to add grease. Not sure if it screws off or just pull out. I don't want to damage anything. it looks like a round head bolt and then a square coming off one side. Sorry no closer picture
[IMG]c:\users\acarter\desktop\oil1[/IMG]\
THis link below take to image of hand crank model a
https://images.app.goo.gl/zdtYCoh6Y1HAApXRA
The Following User Says Thank You to CaptAndy For This Post:
Old 07-11-2019, 12:16:33 PM
enginecrzy enginecrzy is offline
Default Re: Briggs and Stratton model A - oil cup on hand crank
Its an oil cup with a little spring loaded lid.
That little square bit is the hinge sticking off the side of the lid.
Not meant to be removed as it is a pressed fit into the oil hole.
The Following User Says Thank You to enginecrzy For This Post:
Old 07-11-2019, 04:46:15 PM
so just pull on the non hinged side and it will open? Mine looks painted and couldn't tell it was a hinge......and then load with oil/grease?
Old 07-11-2019, 06:49:11 PM
Duey C Duey C is offline
Hadn't looked at the one here in 20 years but your post prompted me to! Mine too, a little flip-top spring loaded cover. I'd ask you to walk up to it and gently use your left hand middle or index finger nail and lift it up. This one here is 45 degrees from yours so I used my right.
EDIT: That ol' boy hasn't ran in awhile. Nice save!
The Following User Says Thank You to Duey C For This Post:
Old 07-11-2019, 07:14:17 PM
I just looked at my 1945 Briggs model B and it also has the Gits oiler. A model B is closely related to the model A with improvements. My two model A's have rope starters, so they don't have use for a oiler.
Old 07-11-2019, 09:54:58 PM
Got it... flipped up really easy. Just didnít see hinge until it was mention... thanks team!
The Following 2 Users Say Thank You to CaptAndy For This Post:
Briggs & Stratton NP Crank bikeguy Small Air Cooled Gasoline Engines 9 01-05-2017 08:25:04 PM
Briggs & Stratton WM? WMB? Hand Crank MasseyMan1089 Small Air Cooled Gasoline Engines 9 07-23-2013 10:53:33 AM
Briggs & Stratton hand start? Nate Bolduc Small Air Cooled Gasoline Engines 11 11-21-2011 07:44:50 PM
Briggs & Stratton Model 23 Crank Identification jjanitor Garden Tractors and Mowers 1 05-24-2011 09:56:36 AM
Briggs & Stratton -Model M hand crank starter patrickdorak Small Air Cooled Gasoline Engines 3 04-08-2010 10:25:19 AM
