briggs and stratton ZZ coil repair
this thread has 5 replies and has been viewed 483 times
Old 07-14-2019, 08:45:51 PM
pigpen60 pigpen60 is offline
Default briggs and stratton ZZ coil repair
I am looking for information on K D Redd's repair of the magneto coils for engines like the ZZ. Right now its for learning. Thank you.
Old 07-14-2019, 11:31:08 PM
EvilDr235 EvilDr235 is online now
Default Re: briggs and stratton ZZ coil repair
I know KD Redd did a magneto upgrade for the later Briggs engines that had Magnamatic magnetos. If you don't get a answer here try shopdogsam on YouTube. He has many, many videos on old engines and repairing them.
The Following User Says Thank You to EvilDr235 For This Post:
Old 07-15-2019, 04:41:48 PM
will do, thank you.
Old 07-15-2019, 07:58:40 PM
Doug Tallman Doug Tallman is offline
Redd's thoughts were to install a coil that was cheap and easy to obtain on the laminations of the original coil.
Here is a link to a search for his posts. Might take a while to find what you are looking for.
https://www.smokstak.com/forum/searc...archid=9005128
---------- Post added at 07:55:37 PM ---------- Previous post was at 07:42:54 PM ----------
Here is a different search for his posts with the word coil included. Should be a shorter list but still 8 pages.
https://www.smokstak.com/forum/searc...archid=9005133
---------- Post added at 07:58:40 PM ---------- Previous post was at 07:55:37 PM ----------
This isn't from Redd but another thread on repair of a Z coil.
https://www.smokstak.com/forum/showthread.php?t=89644
The Following 2 Users Say Thank You to Doug Tallman For This Post:
Old 07-15-2019, 09:14:37 PM
batrider batrider is offline
I looked into this a couple years ago for my Model A which I think has the same as yours. At the time there was someone in the Northwest who rewound the coils. Do a Google search using the part number.
I ended up taking the laminated core apart like Redd did so the coil can come out. I bought a Chinese hand cranked winder with a mechanical turns counter and rewound by hand using wire with modern insulation and Nomex paper between layers. Lots of mylar tape too.It is something like 10,000 turns and took about 4 days of intermittent cranking. The wire is hair thin and broke frequently. All in all I would not do it again. It is well worth having it done by someone else. The cost of materials is not cheap and it is very labor intensive to do it that way. Also experience counts when dealing with insulation and high voltage techniques.
But I learned a lot doing it the hard way and it puts out a nice blue spark. Makes me smile.
Russ
---------- Post added at 09:14:37 PM ---------- Previous post was at 08:50:28 PM ----------
Russ
Old 07-19-2019, 09:53:29 AM
The rewinder in Washington state is oldcroak.com. $125 with your core. Never dealt with them myself.
Sorry for the double post above. It won't let me edit it.
Briggs and Stratton carb repair Tom Jamboretz Small Air Cooled Gasoline Engines 8 06-01-2018 03:11:29 AM
Briggs & Stratton - No Replacement, Repair w/ Individual Parts ClassicTVMan1981 Small Air Cooled Gasoline Engines 6 12-03-2015 07:55:23 PM
Briggs stratton 8hp valve guide repair? fungus Small Air Cooled Gasoline Engines 17 07-11-2015 05:18:42 PM
Briggs and Stratton 195437-0150-01 repair question Justin E Small Air Cooled Gasoline Engines 5 02-02-2013 12:44:23 PM
Briggs & Stratton Horseshoe coil repair/Fix Dennis Wyatt Small Air Cooled Gasoline Engines 4 04-26-2011 05:57:51 PM
