Wisconsin Engines
Wisconsin AGND charging system
this thread has 2 replies and has been viewed 237 times
Old 07-15-2019, 04:02:02 PM
fwdstuck fwdstuck is offline
Default Wisconsin AGND charging system
Hey guys I just picked up a Wisconsin agnd the other day and like always with these engines a little carb and points cleaning they will fire right up. I thought about getting the charging system back working. It has the separate regulator and rectifier. The stator checks out good with about 30vac across the wires. What's that conversion you can do with a modern briggs or Kohler regulator you can do?
Old 07-22-2019, 11:38:05 AM
pigpen60 pigpen60 is offline
Default Re: Wisconsin AGND charging system
Pictures please?
Old 07-22-2019, 12:28:46 PM
Assuming two wires from the stator,
https://www.ebay.com/itm/12V-DC-4-Wi...60ecdb1389ed18
Pink and yellow to stator
Green Ground
Red Battery
Wisconsin AGND starter limekiln Wisconsin Engines 7 04-25-2019 12:46:38 PM
Wisconsin AGND dirtycurt Wisconsin Engines 12 05-25-2012 09:58:31 PM
67 GMC charging system a jossund Antique Autos and Trucks 9 03-19-2012 08:57:45 PM
Wisconsin AGND with PTO TwowheelerVA Wisconsin Engines 8 10-14-2010 07:55:47 AM
Charging System Fred Van Hook Antique Farm Tractors 4 01-30-2007 06:56:10 PM
