Clinton B-760 coil
this thread has 1 replies and has been viewed 254 times
Old 07-16-2019, 08:55:49 PM
Spenser Rynne Spenser Rynne is offline
Default Clinton B-760 coil
Hello, all. Have a little B-760 Clinton on a mud pump I'd like to get going at some point. The coil insulation is completely gone and, naturally, the coil itself has failed.
Some time ago I had loads of old Tecumseh's around, not so anymore. But from what I saw, the coil looked a lot like a 60's Tecumseh internal magneto, say off a push mower.
To those who have found bad coils, is there anything that can be retrofitted?
Old 07-16-2019, 09:27:03 PM
Doug Tallman Doug Tallman is offline
Default Re: Clinton B-760 coil
The old Tecumseh coils are readily available and cheap. I've substituted on a Clinton but don't remember the model. See a post titled Briggs ZZ coil repair for links to KD Redd's coil fixes.
CLINTON 700A Magneto Coil? AJWindmeyer Magnetos, Ignition Coils and Spark Plugs 8 02-10-2016 06:53:57 PM
clinton engine lighting coil gambitace71 Small Air Cooled Gasoline Engines 1 07-31-2015 02:42:20 PM
clinton 525 coil A S Price Chain Saw Collectors 4 01-25-2015 02:35:03 PM
Clinton VS-800 cast iron ~ Coil upgrade PettyMower Small Air Cooled Gasoline Engines 0 08-03-2014 10:00:34 PM
Clinton coil Ed Radtke Small Air Cooled Gasoline Engines 3 12-06-2008 08:28:33 AM
