New Project Trailer/RV
this thread has 350 replies and has been viewed 95278 times
Old 04-25-2011, 03:48:01 AM
ListerDiesel's Avatar
Default Re: New Project Trailer/RV
More on the chassis yesterday, got out there early as we had a lot to sort out.
First, here's a picture of the winch, sat on the new bars before the floor went in:
Next job was to be the brake cables, but we found that the ones for the rearmost axle were about 8" too short, so we fitted the front ones and will get new ones in the week.
Next up was to fix the main floor panel in place, and get the checker-plate drilled and punched and ready for the support spacers to be made.
Took us nearly an hour to get the protective cling film off! :whistle:
Once that was done, we applied Sikaflex 221 on top of the chassis and laid the floor down. It sat down nicely and was pretty firm after an hour, so we went around the edges and filled up the gap between the floor panel and the radius of the chassis beams.
Next job was to get the checker plate out and lay it in place to sort out the fixings. There isn't a lot of force on the plates, just the weight of the engine when it is in there, so we haven't put any Sikaflex on for now, but might do later on.
The holes for the winch and lashing eyes were drilled in the floor and punched in the checker plate, we have to open up the floor holes with a hole saw tomorrow, once we have made the two sets of spacers.
Last picture is all the bits as finished, just waiting for the spacers which we will make up tomorrow.
The end of the checker plate nearest the camera is the extent of the engine section, a full-width bulkhead goes across at that point. From that point forward is the living area.
Sorry the pictures are a bit dull, it was early evening and the white floor gives a false reading for the camera exposure. The winch picture was taken in the morning.
Peter
The Following User Says Thank You to ListerDiesel For This Post:
Old 04-26-2011, 01:55:02 PM
More work in a 4-day holiday weekend, plus we have another 4-dayer next week
Most of the flooring is cut and in place, we use Sikaflex 221 sealer/adhesive to hold the honeycomb floor in place.
Here's what we finished with on Monday evening:
The 24ft side panels and the front panel will be here Thursday, and we hope to erect it all over the weekend.
Peter
Old 04-28-2011, 03:23:18 PM
Truck turned up just past 11am, only had our sheets of Panolit on the back, so we got them off in next door's yard.
As we weren't expecting the delivery until between 2pm and 3pm. we didn't have everything ready, but soon got everything next door plus a power feed.
Took about 3 hours to measure, mark out and cut the two main sheets, the smaller one is the front panel and we will be fitting that first, so the other two have something to hold them square when we erect them.
Fair bit of material in offcuts, hope to make use of that on things inside!
Peter
Old 04-28-2011, 04:33:42 PM
Just had a play around with some offcuts and extrusion, to see how the front corner would work out, and it looks fine. Was just starting to get dark so had to use flash.
Peter
The Following 2 Users Say Thank You to ListerDiesel For This Post:
  #25
Old 04-30-2011, 04:39:14 PM
Working on mitreing the side rave extrusions today, had to go shopping for the weekend (another 4-day break) and went to our local show to look at a Land Rover chassis with our youngest son so only a part-day.
More to follow
Peter
Old 05-04-2011, 03:08:08 PM
Framing for the side panels is complete, floor treadplate is bolted down, brake cable supports to be fitted and just a dimensional check tomorrow before we hoist the two side panels on, each one is 20ft+ long and nearly 8ft high.
Peter
  #27
Old 05-05-2011, 04:06:51 AM
Some small detail:
The floor is 21mm honeycomb, made of GRP outer layers with polypropylene honeycomb inner. Made in China
All fasteners are stainless A2 grade, mainly as I have spent years trying to undo rusted bolts and nuts!
The walls are 14mm GRP/Ply/GRP sandwich, made in France.
The small inner brackets that hold the wall in place are 2mm stainless, laser-cut for accuracy and repeatability.
The roof is 1.3mm GRP sheeting, over top-hat section extrusion. Hope to have some pictures of that later in the week if the wind holds off. We cannot move the side sheets if the wind is too strong, they just get out of control!
Peter
  #28
Old 05-05-2011, 12:54:24 PM
AndyG's Avatar
AndyG AndyG is offline
Images: 7
Looking really good. How does the front axle pivot from side to side when going over uneven ground?
Old 05-05-2011, 02:53:18 PM
It doesn't, Andy, but each wheel has independent suspension, which is progressive in spring rate as the load increases.
Drawbar trailers by their design do not have any side to side pivoting, and the only difference between the front and rear axles is that the front one swivels in an horizontal plane. The wheel centre is level with the axle pivot point, so in effect the wheels are trailing arm suspended.
The suspension is rubber torsion and not obvious in the pictures, have a look at this page, the braked axle beams are about halfway down:
http://www.meredithandeyre.co.uk/ima...0July%2007.pdf
Peter
Old 05-05-2011, 05:23:38 PM
Steve Kunz's Avatar
Looking Good! Nice work!
How fast can you tow it with this 5th wheel draw bar setup?
Old 05-06-2011, 02:58:50 AM
Standard UK/Europe speeds, Steve, 50mph max on single-carriageway roads, 60mph on dual-carriageway and motorways (freeways)
You also cannot use the outside lane on motorways when towing a trailer.
Peter
  #32
Old 05-06-2011, 03:33:30 PM
Absolutely knackered!
Got the front and sides on today, starting to look good:
Peter
The Following 3 Users Say Thank You to ListerDiesel For This Post:
  #33
Old 05-08-2011, 03:08:26 PM
Very productive day, in fact the whole weekend has been good, despite some very heavy rain about 4am this morning, but that had dried up by 10am with the breeze and sun.
We have cut and stuck in place both cant rails (the top of each side) and fixed all the roof bars in place. Just short of one single-sided tophat section to make up the second skylight/vent aperture. In the pictures there is a conventional top hat piece just sitting there.
We get a delivery on Tuesday from Aalco so we can finish the roof and start the rear door.ramp.
Also got to square up the chassis on axle stands before we finally fit the GRP roof, which comes on a roll 2550mm wide and cut to your length, 1.3mm thick.
Outside on offside
Outside on nearside
Single and double sided roof sticks
View from ist floor of the house
Peter
The Following 4 Users Say Thank You to ListerDiesel For This Post:
  #34
Old 05-12-2011, 02:05:25 AM
I made up a set of spacers for the lashing eyes this morning, but got brain fade and forgot to allow for the treadplate.
Made a second set up which worked a treat. Each eye is retained by an M16 bolt below which bolts through a 6mm gusset plate in the chassis corner:
Next up was the rear end and the aperture for the door. First off we had to take out the offside corner pillar and re-seat it, this time we put the screws in that we should have done first time round...
The rear has to have some panelling to give some stiffness to that end of the body, so one across the top full width, and one on either side. Before finally glueing and screwing we check diagonal dimensions to make sure we were square:
The corner castings went in OK, but it was a trifle messy with the sealant!
The nearside vertical panel is waiting to go in, so as we have a self imposed power tool curfew at 7pm, that will be done tomorrow. Two right-angle stiffener plates will be fitted up in each corner and across the panel joint.
Peter
  #35
Old 05-12-2011, 09:28:26 PM
Carried on from yesterday, spent a few hours at the factory then left Rita and the boys to look after things while I came back home.
First job was to put the n/side vertical door panel in place and glued in, that took a while as I couldn't get the closeness of cut I wanted with the circular saw, so resorted to the grinder with cutting disc.
Then I started on fitting the floor outriggers. and quite fortuitously the offcuts from the main honeycomb floor boards were exactly the right size, so just needed the length to be trimmed. Serendipity or what? :whistle:
The new nylon winch rope roller was made up this morning as well, we bought a standard keel roller from Indespension, but the rubber roller was too soft and wouldn't roll with a load on, so we made a new roller out of Nylon and a new pin from brass. The pin was 7/16" diameter, but we found an ebay supplier with some lengths so that was sorted.
The outrigger boards went down OK, the pictured side has three offcuts used as we had them, and that is underneath the toilet/shower so won't be seen.
Lots of threatening clouds and a couple of showers, so had to work under a tarp for most of the day. We have a couple of truck side sheets of heavy PVC/Nylon that we use on the engines, they last almost indefinitely and are totally weather and water proof. One can be seen in the first picture, over the roof rails.
Hope to get the roof on over the weekend, will be doing the wheelboxes tomorrow. The 21mm thickj honeycomb is a good material to work with, but has a slight disadvantage in that you can't screw into it like plywood, but you can bolt through it and use adhesive/sealer to hold it in place.
Peter
Old 05-16-2011, 03:08:06 AM
Roof is on and stuck down, capping bolted on each end for now, but we will replace with rivets tomorrow.
Going to get the divider/bulkhead done next, then the drawbridge when the metal is cut.
Peter
Old 05-16-2011, 03:10:21 AM
This is a bit out of sequence, but shows the roof rails with the double-sided tape on, and the second picture shows the roof material laying in place.
Roof is held in place temporarily while we drill the holes for the rivets. The cant rail and the mouldings are already drilled, just a case of matching it all up and popping the drill through.
Once that is done, we have to trim the back end of the waste/excess material, then will start removing the protective layer on the double-sided tape and get the roll stuck down, then we can rivet the moulding over the top.
Surprised how much light comes through, we were told that it would allow any light through!
Peter
  #38
Old 05-18-2011, 03:12:23 PM
All sorts of things happening on the trailer, main items:
Windows have been ordered now, we were going to use the caravan ones that we had, but decided to go for new with laminated glass.
Extrusion for the door opening was replaced by Aalco, they delivered the wrong extrusion yesterday.
Picked up the modified bed/seat frame today and after laying the new floor covering dowm, had a trial assembly to see how it all looks:
Lots to do yet, but real progress being made now.
Peter
The Following 5 Users Say Thank You to ListerDiesel For This Post:
  #39
Old 05-19-2011, 02:56:27 PM
Today's efforts included fitting the seats/beds in properly, plus we got the kitchen unit and floor covering done this evening.
The small cabinet is normally taken off its mounting if you want the full-size double bed (about 6ft X 6ft 6") but for most folks it is big enough with it in place.
The panels on the walls are anti-condensation screens that let air up behind the cushions and stop damp accumulating.
The adjustment needed was 20mm on each side to make the caravan beds fit the trailer. We had 6 pces of Meranti hardwood cut to 20mm X 40mm and screwed them to the walls each side, then screwed the beds and the panels to them.
Peter
  #40
Old 05-22-2011, 02:17:15 PM
Had a reasonably good day, have tried out a few configurations for the wheelarches/boxes, and after a bit of faffing around with the tape measure, put one together completely and trimmed it up.
We were originally going to get these fabricated in steel, but we had sufficient honeycomb sheet left over to do them both, so that's what we have ended up with.
The inner panel is bolted to the outside face of the main chassis, the top panel is bolted to the side rave extrusion and two filler pieces complete the box, one at each end.
I used some equal angle extrusion to trim the joints as they are a bit unsightly on the honeycomb, and once done they looked quite tidy. I was particularly pleased with the mitres on the corners, they came out really well.
We are going to put a couple of M10 eyebolts into the main chassis risers in the living area, mainly for tying down anything heavy, but will be useful for restraining anything that we want to carry in there.
Peter
they will never fit on the trailer Lee Werth Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 01-04-2006 07:31:32 PM
So now where do I go for a new trailer Steve Gerot Antique Engine Archives 11 03-31-2003 11:52:08 PM
What about your trailer? Tim Claremont Antique Engine Archives 19 02-19-2002 11:00:43 AM
