Sears and Roebuck
this thread has 10 replies and has been viewed 3359 times
Old 11-19-2011, 07:51:42 PM
dbundy dbundy is offline
Default Sears and Roebuck
Another from my friends barn. Sears Roebuck and Co.
Model# 306115
Serial# 1380201
ID:	121274   Click image for larger version
Old 11-20-2011, 05:45:31 PM
K D Redd K D Redd is offline
Default Re: Sears and Roebuck
Are you sure what you list as a Model Number is NOT the engines TYPE number? The engine looks to me to be a Briggs Model N BUT Sear normally lists their supplier number for Briggs (500) in the model number area of the ID Tag.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 11-20-2011, 06:18:51 PM
John Newman, Jr.'s Avatar
Typically, Sears would identify your Briggs engine as a 500.306115. As Kent pointed out, the 500 is the Sears supplier code for Briggs & Stratton and the 306115 would correspond to the Briggs Type number.
With that said, it looks like a Briggs Model N to me, also.
According to the serial number you posted, the chart says it is from May, 1951.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 11-20-2011, 11:09:16 PM
I'll have my buddy check the tag again, have him use a magnifying glass Appreciate the info. How old is the N?
Old 11-21-2011, 04:21:56 AM
Dengine Dengine is offline
The Model N was built from 1940 through 1954, fairly common engine some rare versions like the kick pedal scooter engines. Not familiar with yours as stated but I'm sure if you verify the numbers someone can set it straight. Sure looks like a Model N. Sears did use the 500. prefix for briggs engines sold through them so you should find a 5 or 6 digit number following it.
The Following User Says Thank You to Dengine For This Post:
Old 11-21-2011, 01:04:57 PM
Jim Metzger Jim Metzger is offline
That engine looks like it has a five fin block which makes it 1.5 inch stroke not a 2 inch stroke like a model N would have. With the intake manifold shown it is probably some form of a Model I.
Old 11-21-2011, 03:46:52 PM
grega's Avatar
grega grega is offline
Jim, i counted 6 visible fins and theres another you cant see behind the tag(bottom fin) It is an N according to the sears to briggs convertion chart-Greg
"There only origionial once"
Old 11-21-2011, 07:39:17 PM
The carb. you need is the small Flow-Jet with four bowl screws.
Kent
Old 11-25-2011, 05:41:36 PM
Thanks to everyone for all the info. Checked the tag myself this morning and yes, there is a 500 ahead of the other numbers. It is printed on the tag and not stamped into it like the rest of the numbers. Must be how we missed it before.
Old 06-24-2019, 01:30:05 AM
I know it is a very old thread. I also have the same engine. It has 7 cooling fins, small 4 bolt Flo-Jet carburetor and a recoil starter. It also has a rectangular fuel tank on the right side of the engine while looking at the engine from the front.
500. 306115 serial #1249416
Mine has a burned up connecting rod and very loose crank bushings. I have the parts to rebuild it sometime in the future.
Old 06-24-2019, 06:23:23 AM
Mike in NC's Avatar
Type number 306115 comes back as a model N.
Briggs & Stratton 6-Digit Type Numbers
Briggs & Stratton Information
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Briggs /Sears Roebuck ID DaveHC Small Air Cooled Gasoline Engines 2 06-12-2009 02:32:07 PM
Sears Roebuck and co tractor 83shelby Garden Tractors and Mowers 1 01-03-2009 11:05:12 AM
Sears & Roebuck 2 hp Jim Lee Hit & Miss Gas Engine Discussion 6 06-18-2007 10:26:03 PM
Sears Roebuck engine tom bowler Small Air Cooled Gasoline Engines 1 01-19-2006 08:46:30 PM
Sears, Roebuck Hit and Miss. HELP Jim Tremble Antique Engine Archives 5 12-07-2001 05:42:54 PM
