Fairbanks & Morse Z
this thread has 8 replies and has been viewed 713 times
Old 01-16-2019, 06:55:51 PM
Donnie Hargreaves Donnie Hargreaves is offline
Default Fairbanks & Morse Z
I have a Fairbanks & Morse Z style C self oiling with a 5 3/4 in.bore and 8in.stroke. Can't find serial number anywhere. Trying to figure out hp. & model. Thanks
Old 01-17-2019, 04:05:16 AM
CODY K's Avatar
CODY K CODY K is offline
Default Re: Fairbanks & Morse Z
That sounds to be a fairbanks Morse Z style C model 208 12 hp. Not sure where the serial number may be on it. The older models had a small raised boss on the top of the water hopper, thats were the serial was. The earlier zs had it stamped on the end of the crankshaft. Im not sure of the serial location on the self oiling engines!! Cody
The Following User Says Thank You to CODY K For This Post:
Old 01-17-2019, 12:29:31 PM
DCamp DCamp is offline
Is it not on the crankcase right next to the cover?
The Following User Says Thank You to DCamp For This Post:
Old 01-17-2019, 07:57:38 PM
The brass tag reads 8 hp. @ 550 rpm 9 hp. @ 650 rpm
Old 01-18-2019, 08:23:50 AM
D CAMP thanks for info did find serial no. 819921
Old 01-18-2019, 08:44:25 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Your engine was made in 1940.
Denis Rouleau
2 H.P. Fairbanks Morse H fairbanks67 Hit & Miss Gas Engine Discussion 18 12-10-2014 10:38:21 PM
Fairbanks&Morse 118 fixer1952 Oil Field Engines & Related Equipment 2 01-01-2009 06:00:58 AM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Hit & Miss Gas Engine Discussion 4 09-12-2008 11:03:58 AM
Fairbanks Morse 118 AndyGrogg Oil Field Engines & Related Equipment 3 07-20-2007 03:53:15 PM
Fairbanks Morse 5hp Z Dale Parker Antique Engine Archives 9 07-28-2003 07:11:46 PM
