Lauson Frost King
this thread has 4 replies and has been viewed 2273 times
Old 08-17-2014, 07:13:19 PM
fxrays fxrays is offline
Default Lauson Frost King
Here is an almost new lausen engine I found in a shed with a creek running thru the shed. There was a small generator that was run from a homemade water wheel and the engine was backup. It is a hit and miss type.
It was run very little, there is zero wear on all parts including the brass crank gear and the piston rings still have the machining marks on the,
It has the original battery box with the instructions and coil, original brass oilers, carb and a polished brass timing advance lever.
Had to make new intake and exhaust valves from turning down some Model T valves.
It is only 1 1/2 HP but the flywheels are massive. I was told this was a generator model and the heavy flywheels kept the RPM more constant and hence the generator output more constant. It also has a water cooled head which is not common on this small size. there is a cylinder cock as well to make it easier to start. The compression on this engine is very high.
The only problem is the cast iron base of the engine is also the fuel tank and it is so full of rust and scale, it keeps plugging the fuel suction. Have not figured out a good way to get rid of the problem yet.
ID:	203168   Click image for larger version
The Following User Says Thank You to fxrays For This Post:
Old 08-18-2014, 09:56:04 PM
justintime justintime is offline
Default Re: Lausen Frost King
I know you will laugh but it works fill the fuel tank with nuts any size u can get in the hole. Leave it dry seal it up.???? Then strap it dam tight to a tractor wheel jack it up and let it spin forward and reverse for long time. Then dump out the rust clean it then seal it.Small parts work great wrap it towels tape tight
put in old cement mixer round and round it goes
The Following User Says Thank You to justintime For This Post:
Old 08-19-2014, 12:30:44 AM
Default Re: Lauson Frost King
My bad. I have not looked at the engine for a long time. It is buried! It is a 1 HP, not 1 1/2, sorry.
Unusual to have a water cooled head.
Few more pix. The timer lever and ground point. Notice it is on the push rod so when it is "missing" the battery is not grounded and the coil is not firing. The advance lever has the other end of the battery connections connected to that clip.
The rocker arm has a nicely polished brass head and a limiter to help pull the intake closed.
The name tag and water hopper.
Name:	Timing Contacts_resize.jpg
ID:	203403   Click image for larger version
ID:	203404   Click image for larger version
Name:	Name Tag_resize.jpg
ID:	203405   Click image for larger version
Name:	Water Jacket_resize.JPG
Old 07-14-2019, 11:01:58 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
I wanted to bump this old thread for a good friend, Tom Nowak , he recently bought this engine and made a vacation out to Idaho to pick it up, VERY NICE 1 hp !! I was looking at old Lauson threads and run across this.. I have a YouTube of it or maybe Tom will put a vid on ..https://youtu.be/BlC4OuZSaPg it is at the very first show at Denmark Iowa , I was hoping it would fit on a flat car on the model train next to it, to make a unique video, up close to make it look like a BIG Frost King, on a BSNF model train, but the flat car wheels where messed up ,lol
United Gasoline Engine Registry www.augermo.com
The Following User Says Thank You to Rich Mueller Sr For This Post:
Old 07-14-2019, 11:44:06 PM
Tom Nowak Tom Nowak is offline
Thanks Rich. I will see if I can up load a few pictures if you have a video of it go ahead
ID:	339088   Click image for larger version
ID:	339089   Click image for larger version
ID:	339090   Click image for larger version
The Following 4 Users Say Thank You to Tom Nowak For This Post:
Lauson Frost King Mtype Hit & Miss Gas Engine Discussion 0 09-01-2013 04:45:49 AM
John Lauson 3hp Frost King jonct Hit & Miss Gas Engine Discussion 10 06-29-2010 06:35:12 AM
Lauson Frost King Jr a little help needed Randy Reysen Hit & Miss Gas Engine Discussion 0 12-14-2009 02:21:34 AM
Lauson Frost King mag gear NICK Antique Engine Archives 0 03-19-2004 07:25:27 AM
LAUSON FROST KING 6HP allen lapage Antique Engine Archives 1 10-19-2001 06:37:49 AM
