Ran onto this today!
this thread has 36 replies and has been viewed 4038 times
Old 06-17-2019, 10:52:37 PM
ronny p 148 ronny p 148 is offline
Default Ran onto this today!
3/4 HP they want 350 firm what you all think ? Fella says it’s all original Mag has weak spark a I know this can cost as much as they want for it !
The Following 3 Users Say Thank You to ronny p 148 For This Post:
Old 06-18-2019, 02:22:50 AM
Ray Cardoza's Avatar
Default Re: Ran onto this today!
pretty good to me. i paid way more for mine but its a buzz coil/battery version
Old 06-18-2019, 05:26:46 AM
JSWithers JSWithers is offline
Looks like a pretty good deal. Even if you have to spend that much more to get the mag worked on.
Old 06-18-2019, 06:05:32 AM
G.M.Johnson G.M.Johnson is offline
I have one just like it. Paid $350 for it and mine was not as clean,
and it also has weak spark. It still starts and runs great though.
Old 06-18-2019, 10:13:23 AM
Kevin Weis Kevin Weis is online now
I'd say that's a go.
Old 06-18-2019, 04:08:00 PM
Ideal model R? Looks nice. Take out the spark plug and roll over to check the crank ball bearings. If it has a WICO EK, it probably wont need much to repair - sometimes just a magnet recharge will do. If the mag is missing, that's another story, then it gets expensive. The EK is easy to work on. One note - these engines run fast and tend to bounce a lot unless you have a good sized skid under them. They were not balanced well - they depended on the 600 pound mower they were mounted on to keep the bounce down!
Old 06-18-2019, 05:22:14 PM
Well I purchased this engine today the man who sold it too me was not in very good shape I took me 14 year old granddaughter with me ! She helped me load it I thought $350 was little steep but most here said grab it will take more photoes later ! We didn’t run it he was not well at all looks ok I hope !
The Following User Says Thank You to ronny p 148 For This Post:
Old 06-18-2019, 08:57:55 PM
Haven’t even unloaded it need help granddaughter will be back tomorrow don’t know what I would do with out her !! I know nothing on how to get this engine started !
Old 06-18-2019, 11:19:57 PM
How do I start this engine ? And run it ?
Old 06-19-2019, 09:18:05 AM
Need some help here Fellas !
Old 06-19-2019, 10:23:11 AM
Antiquebriggsguy Antiquebriggsguy is offline
I'd say start by making sure all parts move freely. Then lube anything that needs to be lubed. Then get some fuel in tank and make sure it gets to mixer. Make sure spark and exhaust valve are timed properly. Crank flywheels. Sit back and enjoy.
Old 06-19-2019, 01:37:24 PM
I knew you were going to get technical on me intake and exhaust valves timed ??????
---------- Post added at 01:37:24 PM ---------- Previous post was at 01:34:09 PM ----------
Drips per minute on Oiler and 30 weight ?
Old 06-19-2019, 01:48:23 PM
Dale Russell Dale Russell is online now
6 to 10 drops per minute.
Old 06-19-2019, 02:14:07 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is online now
Are you able to visit with the seller? He may be able to help you better than any of us here since he is familiar with the engine. It looks like that engine has ball or roller bearings and a sealed crankcase. You should probably open it up. You will then be able to inspect it and clean it out. Make sure you have the appropriate amount of non detergent oil in the crankcase. As others have stated he want to make sure everything is well lubricated and moving freely. Are there any other collectors that you know of that are close to you that could assist?. Good luck.
The Following User Says Thank You to Joel Mosley For This Post:
Old 06-19-2019, 02:15:24 PM
The exhaust valve should close at TDC aftter the echaust stroke. The intake is atmospheric, so no timing there. On retard or start, the magneto should trip at TDC Compression. The mag should trip with an audible click, and open the poles evenly. If the pole shoe does not open evenly, you will get weak spark. Look at the bottom of the mag and you will see a movable piece of metal that bridges the poles on the core. It should snap open evenly. The fuel valve should be openned about 3/4 turn. Lift the pin sticking out the bottom of the mixer until gas flows out. Grasp the flywheels at the top, facing the rear of the engine and pull toward you. The engine should start within a turn or two. Once it starts, adjust the fuel so the engine does not smoke black, and you should be good. As I stated earlier, you want the engine on a heavy mount, as they tend to 'walk'. On the left side of the engine (mag side), there is a weight inside the flywheel that is the governor for the hit and miss system. Make sure it is not stuck.
Tes, SAE 30 oil in the oiler. If you have the engine running, and it tosses oil out thhe breather screen, it may have too much oil in the crankcase. There should be a drain at the rear of the engine, let some oil out now and then. With those small flywheels and the large bore and stroke, that engine needs to run fast to carry over to the next compression stroke. You cannot slow them down much.
Old 06-19-2019, 09:27:02 PM
Thanks Andrew no the fella is couple hours from me I’m not sure how he Aquired engine he was not well and didn’t know much about it ! I just inquired here and most said for price go get it do it’s all you guys fault !! ������ Well I’m at adds with it so I just may take it to s show and see if I can get someone to help me the fella said he tried to start it and it had low spark and said he got it to fire a few times ! I haven’t had time to post pics to get at oil sump cover on top doesn’t look like it’s been off in s while is ther an oil level mark in there 30 weight in there ?
Old 06-22-2019, 05:04:59 PM
Well was looking engine over today I have many more ? I need to know everything about running this engine ! Do here goes some ? Seems to be two positions the wico mag lever can be put in even way back towards rear of engine towards crank housing ! Changing oil in sump how much is supposed to be in it ? Old grease fitting on fan pulley the type that has points on it how do you grease it I don’t have one of them ends for my gun ? Adjustment on fuel mixer how far open to start ? Changing oil will it ruin that gasket taking the cover off with the vents in it and do you clean the vent material and with what ?? Choking it how many revolutions with hand on mixer? Where rod runs on flywheel rub little oil on it ? Did I leave anything out oh ya put in some gas 😀 sorry for all the ? I’ve never run hit and miss !!
Old 06-22-2019, 06:11:00 PM
Some pics of it
ID:	337709   Click image for larger version
ID:	337710   Click image for larger version
ID:	337711   Click image for larger version
ID:	337712   Click image for larger version
Old 06-22-2019, 06:18:57 PM
JFleury JFleury is offline
I see you are in vermont Orange Mass engine show is next weekend if you can make it you will find all the help you need and one of the vendors probaly had a repro manuel
The Following User Says Thank You to JFleury For This Post:
Old 06-22-2019, 06:58:50 PM
Wash out cast gas tank ? What did you all use ?
---------- Post added at 06:58:50 PM ---------- Previous post was at 06:54:22 PM ----------
If you run into a repo Manuel if you would pick it up I’ll pay for it and postage !! I’m on call at my work can’t make it my work really limits my show attendance !
Something else I saw today Doug Waggonner Hit & Miss Gas Engine Discussion 17 04-25-2005 02:17:21 PM
Got my G.E.M. Today; Dale Russell Antique Engine Archives 1 06-08-2004 01:10:30 PM
