Economy 1 1/2 engine head threads
this thread has 5 replies and has been viewed 458 times
Old 07-09-2019, 11:18:44 PM
VicF VicF is offline
Default Economy 1 1/2 engine head threads
Hi, I had purchased a new head for my Economy 1 1/2hp E engine as the old one had a broken valve guide. I couldn’t get the exhaust or carb to thread all the way so I purchased a 3/4 NPT tap and a 1” NPT tap. The exhaust threads cleaned up just fine but I can’t get 3/4” tap past half an inch before it won’t really budge. I don’t want to force it to much. Any suggestions want to do here?
Old 07-10-2019, 06:15:53 AM
26kracing 26kracing is offline
Default Re: Economy 1 1/2 engine head threads
they don't thread in all the way
Old 07-10-2019, 07:54:56 AM
On the old head they did.
Old 07-10-2019, 11:19:41 AM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Pipe threads are a taper fit to lock in place and seal. If you bottom the tap out, If the carburetor and street ell for the muffler bottom out, you have defeated the mechanical purpose of the pipe thread design.
I am sure the quality control was not that great on these tapped holes on the head so there was quite a bit of variation. As long as they thread in and get snug, you should be fine.
Old 07-10-2019, 11:28:49 AM
Heins Heins is offline
If it is a NPT it should go in more than 1/2". Can you see threads that go in more than 1/2"?
Old 07-10-2019, 02:18:23 PM
Skip Landis Skip Landis is offline
I believe the pipe nipple was cast in when they poured the head, so the metal beyond the nipple is likely hard from the process .
sealing up head stud threads jackel440 Hit & Miss Gas Engine Discussion 11 08-16-2013 06:46:47 AM
Repair/Replace Threads on Briggs FH Head Stevie Mote Small Air Cooled Gasoline Engines 20 04-13-2011 09:16:01 PM
IHC LA 3-5hp Head (Threads on muffler) Stevie Hit & Miss Gas Engine Discussion 2 02-03-2010 11:11:13 PM
2.5 hp Economy head 1LungerKev Hit & Miss Gas Engine Discussion 1 02-17-2009 10:18:36 PM
2.5 hp economy head 1LungerKev Hit & Miss Gas Engine Discussion 0 02-17-2009 09:52:19 PM
