Associated (The Milwaukee) Engine
this thread has 8 replies and has been viewed 718 times
Old 07-13-2019, 08:40:12 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Associated (The Milwaukee) Engine
Today I picked up an Associated built engine. It was sold here in Quebec by P.T.Legare under the name "The Milwaukee".
I'm not too familiar with Associated engines but I know many here are. I thought that the first digit in the serial number was the horsepower. My engine is serial number 420359 on the name tag and also stamped on the end of the crank shaft. Since the first digit is a 4 I thought the engine should be a 4hp but the name tag clearly indicated 6 horsepower.
What can you tell me about it?
Denis Rouleau
ID:	338996   Click image for larger version
ID:	338997   Click image for larger version
The Following 5 Users Say Thank You to Denis Rouleau For This Post:
Old 07-13-2019, 09:39:23 PM
DavidRaines DavidRaines is offline
Default Re: Associated (The Milwaukee) engine.
Dennis, Associated related their engines (Iowa Oversize) and the 4 hp became a 6 hp. Basically the same but had a couple changes most notably is the hopper extends over the head. A lot of manufactures just changed the rpm to get more hp.
The Following 4 Users Say Thank You to DavidRaines For This Post:
Old 07-13-2019, 11:12:22 PM
Don Tomlinson's Avatar
Don Tomlinson Don Tomlinson is offline
David nailed it !
Old 07-14-2019, 05:00:19 AM
Is it known in what year this Iowa oversize was built?
Denis Rouleau
Old 07-14-2019, 07:54:04 AM
Dennis, the records from the factory have never been discovered so an exact year would be impossible. There are some dates/serial numbers in the operating/repair manuals that one can go by. Your engine is a high serial number which leads me to think late 1920’s. Just my guess. Somebody may chime in with a better guess.
The Following 2 Users Say Thank You to DavidRaines For This Post:
Old 07-14-2019, 09:27:47 AM
If my engine is in fact an "Iowa Oversize" and I have no way to tell for sure, and when I checked some old ads I have, the first time the term Iowa Oversize was used was in November 1920.
Anyone know in what year Associated built their last engine?
Denis Rouleau
Old 07-16-2019, 11:07:48 PM
I took a few more pictures of my 6hp Milwaukee.
They can be seen here: http://buzzcoil.brinkster.net/associated/page102.html
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
Old 07-17-2019, 12:45:23 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Re: Associated (The Milwaukee) Engine
hi Dennis, you have a nice engine. I have a 6hp that is different than yours. mine has a webster mag setup, taller base, big opening for the water hopper and bigger flywheels.
ID:	339254   Click image for larger version
The Following User Says Thank You to Firewoodguy For This Post:
Old 07-17-2019, 12:47:47 PM
another pic I have with my truck at the jacktown show from last fall.
Milwaukee / Associated Engine Denis Rouleau Hit & Miss Gas Engine Discussion 18 12-03-2017 10:43:20 AM
CH&E Milwaukee gas engine MoteurCeres Antique Engine Photos 2 01-22-2015 06:22:51 PM
milwaukee engine Rodbolt Hit & Miss Gas Engine Discussion 0 04-22-2013 07:05:53 AM
associated jobber engine Milwaukee Vince Lindaman Hit & Miss Gas Engine Discussion 0 05-02-2006 03:55:32 PM
MILWAUKEE ENGINE (ASSOCIATED) TOM GOSCIMINSKI Antique Engine Archives 0 07-18-2003 09:16:11 PM
