Need help identifying a hot air engine - is anything missing?
this thread has 4 replies and has been viewed 717 times
Old 07-14-2019, 02:09:19 PM
Travis Benner's Avatar
Travis Benner Travis Benner is offline
Images: 24
Default Need help identifying a hot air engine - is anything missing?
I would appreciate some help identifying a hot air engine. Anyone know any background on this piece?
And who can help tell me what might be missing?
And would anyone have details on how the burner works or share if they’ve tried an external burner?
Thanks very much for your help!
ID:	339038   Click image for larger version
ID:	339040   Click image for larger version
ID:	339041   Click image for larger version
ID:	339042   Click image for larger version
Travis Benner
Blue Grass, Iowa
Check out my videos and subscribe: Search "Travis Benner" on YouTube
The Following 14 Users Say Thank You to Travis Benner For This Post:
Old 07-14-2019, 03:03:40 PM
Brent Rowell Brent Rowell is offline
Default Re: Need help identifying a hot air engine - is anything missing?
Travis,
What you have was made in several different versions from the 1910s to the mid-1930s. They're called "Duplex Vacuum Motors" even though they were air cooled hot air engines (nothing to do with a vacuum motor). Yours is the later model from the 1930s when the co. was called Kessler Motor & Engineering in Chicago. Most of them are missing the swinging door on the firebox which has the name of the company cast into. The man behind these engines was Chicago resident and German immigrant Louis Kessler who apparently got many of his ideas from German water-cooled Heinrici engines.
The tank is for the kerosene burner which may be missing (?). The tank was pressurized by the engine itself producing a nice strong flame without smoke. You can see these and get some background on the engine from my video:
https://www.youtube.com/watch?v=KqQCCLEKIx0
You can also run it with a bunsen burner on propane.
This post should be moved to the Hot Air Engines section.
Old 07-15-2019, 08:25:57 AM
JSWithers JSWithers is offline
There is a building at Rollag with a nice display of hot air engines. You could probably get some more info on hot air engine operation from the group in that building. Seems there might be one like this. There is quite a variety of hot air engines on display.
The Following User Says Thank You to JSWithers For This Post:
Old 07-15-2019, 08:50:56 PM
Images: 24
Brent - thank you very much for your good info. And your video was also quite instructive. Big thumbs up!
Quick question, do you or does anyone else know of someone who is reproducing the door I am missing that has the name?
J.S., thanks for the tip about Rollag. I’m hoping to make the trip to that show soon...
Thanks again,
Travis
Travis Benner
Blue Grass, Iowa
The Following User Says Thank You to Travis Benner For This Post:
Old 07-17-2019, 11:25:25 PM
Inverted's Avatar
Inverted Inverted is offline
Travis: Here is a couple of photos of a small Hot Air engine that I picked up a while back. Was told it was made in the Nordic area of the World??? It dose look some what like the one you have?
It is a small one with flywheels about 16" dia. and not sure of the piston but will check. - Ted
ID:	339295   Click image for larger version
ID:	339296   Click image for larger version
ID:	339297   Click image for larger version
Old enough to know I won't get all the projects done that I have started BUT young enough to still think I can
The Following 2 Users Say Thank You to Inverted For This Post:
Ernst Plank steam engine Help identifying model and missing parts please. RedOctober Vintage Toy Steam Engines and Motors 9 08-27-2017 07:00:21 PM
Engine Missing dieselman2000 Hit & Miss Gas Engine Discussion 11 07-06-2017 07:16:17 PM
How much is a Maytag 92 engine washing machine worth with no engine and missing a leg Hit and Miss kid Maytag Engines and Collectibles 13 10-13-2009 07:20:22 AM
Engine missing HELP! Chris Page Hit & Miss Gas Engine Discussion 27 03-15-2009 11:25:48 PM
Unknown missing engine Torleif W Hit & Miss Gas Engine Discussion 2 09-08-2006 02:39:56 PM
