John Deere Model E 3HP Speed
this thread has 3 replies and has been viewed 269 times
Old 07-15-2019, 05:06:55 PM
Dutch Dutch is offline
Default John Deere Model E 3HP Speed
The manual for this machine says speed can be adjusted from 50% to 100% [i assume by the governor] what is actually the rpm range of this motor?
Appreciate the help!
Am trying to determine if this is a good match to run a JD2 sheller - HP seems right and am trying to confirm speeds with 6" motor pulley and 10" sheller pulley.
The Following User Says Thank You to Dutch For This Post:
Old 07-15-2019, 08:14:10 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Default Re: John DEERE MODEL E 3HP SPEED
Most engines in that HP range seemed to be in the 500-600RPM range. so 6/10ths of 600RPM is 360RPM, which is too fast. I think most shellers like to be about 100RPM give or take.
Old 07-15-2019, 09:19:33 PM
Mike Monnier's Avatar
Hoarder
Deere engines are typically rated at 600 rpm. Theoretically you can slow one down to 300 rpm. Generally it takes a little fiddling to get the engine to run right that slow. Usually the speed adjustment spring lacks sufficient tension to keep the engine running at that speed.
Old 07-15-2019, 09:36:35 PM
Thanks. If the motor can be set to operate at 300 rpm and using the pulley ratio of 6”/10” or 60% - the sheller should operate at 180 rpm which should be well below the 300 rpm rated max for the sheller.
John Deere E speed control naterackers Antique Gas Engine Discussion 4 10-26-2017 09:27:45 PM
John Deere E 1.5 hp speed nut naterackers Antique Gas Engine Discussion 2 10-05-2014 09:49:59 AM
John Deere Tye E ! 1/2 Speed Change Nut hulou Antique Gas Engine Discussion 6 09-26-2013 09:26:39 AM
John Deere Type E 1 1/2 HP Speed change Nut hulou Small Air Cooled Gasoline Engines 0 09-25-2013 05:48:24 PM
3 H.P. John Deere speed Tanner Remillard Antique Engine Archives 1 12-21-2000 03:59:51 PM
