Lazier gas engine co
this thread has 5 replies and has been viewed 813 times
Old 07-17-2019, 05:56:50 AM
Nick McCue Nick McCue is offline
Default Lazier gas engine co
Howdy all, just picked up this little lazier engine. Was used on the outskirts of Canberra. After any info as Iíve not found much at all. Any help will be great. Nick
ID:	339230   Click image for larger version
ID:	339231   Click image for larger version
ID:	339232   Click image for larger version
ID:	339233   Click image for larger version
The Following 12 Users Say Thank You to Nick McCue For This Post:
Old 07-17-2019, 06:55:11 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Re: Lazier gas engine co
Nick, I think your engine was built in either 1905 or 1906. The reason I say that is because your engine has a "Lazier" name tag and by 1907 these engines were built under the name "Du Bois Iron Works, Du Bois Pa.".
Denis Rouleau
ID:	339234   Click image for larger version
The Following 3 Users Say Thank You to Denis Rouleau For This Post:
Old 07-17-2019, 08:49:41 PM
Rob Leonard's Avatar
Rob Leonard Rob Leonard is online now
Sure looks a lot like this Peerless built in Lansing MI
ID:	339286   Click image for larger version
The Following 4 Users Say Thank You to Rob Leonard For This Post:
Old 07-19-2019, 04:26:05 AM
Heck that’s pretty much identical apart from the head. Would love some more photos. Thanks for the input Rob
The Following 2 Users Say Thank You to Nick McCue For This Post:
Old 07-19-2019, 09:15:31 PM
Here are a few more, its currently torn down waiting to get bored and sleeved. Im sure they both came from the same foundry just not sure where. Rob
ID:	339445   Click image for larger version
ID:	339446   Click image for larger version
ID:	339447   Click image for larger version
The Following 2 Users Say Thank You to Rob Leonard For This Post:
Old 07-20-2019, 07:12:48 PM
Thank rob, looks great. If you ever get near a foundry would love a copy of the carburetor cap. Thanks again nick
5 HP Lazier running Chris Austin Hit & Miss Gas Engine Discussion 4 01-25-2011 07:57:03 PM
5 Hp Lazier restoration part-2 Chris Austin Hit & Miss Gas Engine Discussion 10 01-22-2011 07:48:28 PM
5 Hp Lazier Restoration Chris Austin Hit & Miss Gas Engine Discussion 21 12-18-2010 03:14:24 AM
