Friction Wheel Magnetos and Engines
this thread has 7 replies and has been viewed 959 times
Old 07-17-2019, 09:24:40 AM
Target Driller Target Driller is offline
Default Friction Wheel Magnetos and Engines
Hi all,
just thought it would be interesting to view the several variety of engines of all sizes and types that are setup having a friction wheel magneto / dc generator that drives against the flywheel.
Engines w/ Motsinger Autosparker, Wizard, Comet, Apple, Star, and various others.
If you have one of these types of engines and want to share it here post up your photos into this thread.
The Following 2 Users Say Thank You to Target Driller For This Post:
Old 07-17-2019, 09:41:27 AM
JoeCB JoeCB is offline
Default Re: Friction Wheel Magnetos and Engines
I'll kick start the thread with a pic of a Wizard mag friction drive governor.
Joe B
The Following User Says Thank You to JoeCB For This Post:
Old 07-17-2019, 10:46:27 AM
Heavy Metal Heavy Metal is offline
Here is a picture of my 10hp R&V with a Wizard. You can also see it in the video as well as a 4hp R&V short side shaft with a Wizard.
https://youtu.be/jFCLj4oiCLI
Name:	R&V 10hp SS.jpg
The Following 4 Users Say Thank You to Heavy Metal For This Post:
Old 07-17-2019, 12:12:15 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
This 5hp Galloway round rod, no. 15103 has a original Hendrix Novelty Co dynamo, when we found it in Sharpesburg Iowa in a feedlot all stuck and bare as a babies butt, the old farmer told us he had the magneto in the barn somewhere, 2 yrs later out of the blue, Dad got a call from him and made a special trip to Iowa to get it. It has the original coil that sits in between the magnets to, we first thought that was a addition, but I have read they have to have the coil to get the required spark to igniter, if I remember right the last time I had it going it will put out about 14-18 volts....
Name:	user31272_pic4882_1305307805 5hp round rod.jpg
United Gasoline Engine Registry www.augermo.com
The Following 4 Users Say Thank You to Rich Mueller Sr For This Post:
Old 07-17-2019, 12:42:51 PM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
Motsinger on 8hp 1907 IHC worked well.
The Following 2 Users Say Thank You to Gene Fisher For This Post:
Old 07-17-2019, 09:20:08 PM
I’ve got a base-mount style Motsinger that I’d like to mount on my 6 HP Famous, but it takes a different base than what I have. (I have the correct, early mounting bracket). Does anyone have a side mount base that they would sell, or be willing to get a casting made from?
Thanks,
Mike
Old 07-19-2019, 12:57:14 PM
Larry Evans's Avatar
Larry Evans Larry Evans is offline
Here are some pictures showing the friction drive generator on the 1911 Fairbanks Morse 50 hp. type RE engine at the Mount Wilson Observatory near Pasadena, Calif. The first two images show the original mounting with it being driven by a pulley attached to the inside of one of the flywheels. At some unknown point in the engines history the system was modified to the way it is now shown in the rest of the pictures. It has been converted into a small motor/generator set driven by a small DC motor. It still works just fine and I am sure the early engineers at the observatory found it more reliable than the friction drive.
Larry
ID:	339381   Click image for larger version
ID:	339382   Click image for larger version
ID:	339383   Click image for larger version
ID:	339385   Click image for larger version
Larry Evans
http://www.oldengine.org/members/levans/
The Following 9 Users Say Thank You to Larry Evans For This Post:
Old 07-19-2019, 11:12:52 PM
Chris Epping's Avatar
Chris Epping Chris Epping is offline
Here are a few from Columbus and Callahan engines.
ID:	339459   Click image for larger version
ID:	339460   Click image for larger version
The Following 5 Users Say Thank You to Chris Epping For This Post:
Gas Engines that used Webster Magnetos JimDoyle Hit & Miss Gas Engine Discussion 11 06-23-2017 08:24:48 AM
David Bradley Friction Wheel Questions Warren Eastham Garden Tractors and Mowers 8 01-23-2011 09:55:26 PM
Small engines and magnetos with magnets and keepers Ronald E. McClellan Small Air Cooled Gasoline Engines 10 11-26-2008 10:26:02 AM
Magnetos Used on Edwards Engines? Larry K Magnetos, Ignition Coils and Spark Plugs 2 10-20-2007 11:11:43 AM
Associated/United engines with Webster magnetos Dick Webber Hit & Miss Gas Engine Discussion 12 09-29-2005 05:20:16 PM
