Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Gardner Marine Engine ID
this thread has 5 replies and has been viewed 533 times
Old 06-27-2019, 11:17:39 AM
rodlloyd rodlloyd is offline
Default Gardner Marine Engine ID
Can anyone id the marine Gardner engine in the attached photos. It is in a canal boat Frederick II that I am in process of purchasing in Scarisbrick Lancs.
ID:	337949   Click image for larger version
ID:	337950   Click image for larger version
ID:	337951   Click image for larger version
ID:	337952   Click image for larger version
Old 06-27-2019, 03:53:27 PM
K-Tron K-Tron is offline
Default Re: Gardner Marine Engine ID
Welcome to smokstak. The engine in your boat appears to be a Gardner 6LW. Gardner's are regarded as some of the finest diesel engines ever built. They are incredibly smooth, reliable and efficient. A true masterpiece of British engineering. Sadly there are very few Gardner diesels, and Gardner mechanics in the United States. Good luck with your new boat!
Old 06-30-2019, 01:42:05 PM
Is there any way to estimate its age. It is on a boat on the English canals.
Old 07-02-2019, 03:30:21 AM
oldgoat oldgoat is offline
Email NOT Working
have a look here www.gardnerengineforum.co.uk
Old 07-03-2019, 02:29:45 AM
Peter Short Peter Short is offline
I have been looking through a Gardner book (L. Gardner & Sons Limited: Legendary Engineering Excellence by Graham Edge) and wonder if the engine may be a 6LX rather than a 6LW?
I am not a Gardner expert at all, but the breathers on the side of the cylinder head look like 6LX to me.
I am happy to be corrected however, as the 6LW was apparently still being built long after the 6LX was in production, perhaps breathers were fitted at a later date?
Some stats from the book:
The 6LW was built from 1931-1974, approx. 100hp, 8.4 litre, 511 cubic inch.
The 6LX was built from 1958, approx. 150hp, 10.45 litre, 638 cubic inches. This engine had cross bolted main bearings, so there should be bolts or studs visible on the lower sides of the crankcase I guess.
Then came developments of the 6LX, e.g. 6LXB in 1966, approx. 180hp, then the 6LXC in 1978, approx. 200hp.
I don't know much about canal boats either, except the narrow boats I have seen in the UK seemed to have small 2 cylinder diesels or something along those lines.
A 6 cylinder Gardner is by comparison huge, I guess the Frederick 2 must be something different.
Gardner engines have a legendary status in the British Commonwealth, probably rarely heard of in the US I would guess.
Old 07-03-2019, 07:41:53 AM
I just got a copy of a survey of the boat. It says "Propelling Machinery Gardner 6 LXB 6 cylinder normally aspirated diesel engine"
The sales flyer says it is "150HP", which is way over-sized for the canal, but better suited for the rivers.
The sellers says "The engine has been marinized to cope with rivers and canals and has no problems at low speed" what ever that means. There were concerns about keeping down to the canal speed limit of 4mph and 2.5mph when passing moored boats. It might spend long periods at very low rpm's.
Gardner Engine peter coleman Smokstak Down Under 5 06-18-2018 09:20:40 AM
Gardner engine dating isandian Smokstak Down Under 2 11-02-2015 08:18:04 PM
Alyn Foundry Gardner? engine help please Kelshay Scale Model Engineering 6 09-20-2015 04:35:01 AM
Gardner 6LXB Marine Diesel First Start Up Video Don Carson Vintage Diesel and Oil Stationary Engines 18 02-11-2013 08:33:09 PM
Gardner steam/gas engine (identified) Skidmore Oil Field Engines & Related Equipment 16 04-19-2012 06:36:27 PM
