Go Back   SmokStak > SmokStak® General Off Topic Discussion > Antique Autos and Trucks
Republic Truck
this thread has 15 replies and has been viewed 9030 times
Old 01-30-2012, 10:12:17 PM
Pete Mandt Pete Mandt is offline
Default Republic Truck
I have picked up a Republic truck and am trying to learn as much about it as possible. I am looking for engine pictures. Did they ever use a Buda engine? I have seen some information listing Continental, Waukesha and Lycoming. The engine I am looking at has some Buda characteristics, however I am not an expert on any of these engines. Maybe they look more alike than I think. It is a four cylinder. Just wondering.
Thanks,
Pete
The Following User Says Thank You to Pete Mandt For This Post:
Old 01-31-2012, 01:38:10 AM
Default Re: Republic Truck
Republic, 1912-1929/31, Alma Motor Truck Co, Alma MI, name changed to Republic Motor Truck Co 1914, like many "assembled" trucks of the period, used an array of vendor engines.
Republic merged into commercial div of American LaFrance in 1929, forming LaFrance-Republic Corporation; some "Republic" trucks were built into 1931 but exported to the UK. Sterling bought LaF-R in 1932, continuing to sell LaF-R badged trucks to 1942. (All per Mroz's truck book).
Eyeballing a couple catalogs shows various Lycoming, Cont and Wauk 4s, but no Buda; however, other models not listed in those two catalogs may've had Budas.
D'you have a body tag with a model number, and do you know the year?? (I asume there's no engine tag left).
Old 02-02-2012, 09:11:09 PM
Bud,
I am not familiar with any of these engines from this time period. I was basing my similiarity to Buda on pictures I had seen on another thread on this forum. It looked alot the the Buda in the MH tractor #2? or #3? other than this one does not have a removable head. I have been told that it is a Contintental and have no reason to doubt it with my limited knowledge of these old trucks and engines. I do not know if there is an engine tag or not. I have not personally seen the truck, just the pictures. Bought it based on the pictures. Always a hell of a good idea! Will have more information in a month or so when I get it home.
Here is a picture of the engine.
Old 02-10-2012, 03:22:29 AM
Manuel Manuel is offline
There is some Republic literature on the e bay at the moment.
Item number: 270905548553
Manuel in Oz
Old 06-04-2012, 02:39:31 AM
mgy125 mgy125 is offline
Hi...I am new to this forum and found this thread because we are restoring a 1919 Republic Model 10 truck. Do any of you know of sources for workshop manuals or detailed technical drawings etc for this truck. We are working a bit blind at the moment and would appreciate any help you can give.
Old 06-04-2012, 12:48:45 PM
vern0n's Avatar
vern0n vern0n is offline
Just go down to your local Republic dealership. Ebay turns up some good stuff sometimes. Hennings also. If you have some patent numbers, do a search on them.
Old 06-04-2012, 01:46:07 PM
Pete do you have any more pictures of this truck that you can share with us? as i have not seen a Republic truck before.John
Old 06-05-2012, 01:13:57 AM
MGY: Per my Power Wagon 1919 specs your Model 10 is a 1Ton--
Cont "N" engine, 19.5 SAE HP, Ruggles governor, Stromberg carb, Bosch mag, no water pump (thermo-syphon), "own" (??) radiator, Fuller multi-disc clutch, Fuller sliding gear 3 speed trans (gearbox),Internal gear Torgenson rear axle, 1/2 springs front and rear (maker not stated), wood Prudden wheels with 34x3 front and 34x4 read solid tires (no duals on rear), Jacox steering gear, Savage pressed steel frame, 124 inch WB, hand crank start.
Unfortunately those specs do not say WHICH Bosch mag, WHICH Stromberg carb, etc, etc, so they're only a start. I don't know if Republic printed repair manuals or relied on/referred owners to manuals from their various suppliers. Good luck.
PETE M: While looking this up did note Republic had a 6Ton in the July specs that had a Buda HU; it wasn't in the Dec specs.
Old 06-15-2012, 09:12:50 PM
Bud...thanks for the info. It all helps. Tom
Old 01-20-2013, 08:15:37 PM
Epley Epley is offline
Pete
My organization has obtained a donated Republic Truck billed as a 1913 but I am leaning more to 1915-16. At any rate it has a Buda Engine with data plate id OU-1015 serial 17696. It looks just like your engine pictured above. Three "experts" told us that Republic never put a Buda in their trucks but I found a 1916 ad that said they did. Also found two testimonials from owners in 1916 talking about the Buda Engine in their Trucks. Can't find out much about them or a serial number on the truck but the Axle it has was from a company that went out of business on 1 Jan 1917. Like you we are looking for more info. Clint
Name:	engine buda name - Copy (800x600) (640x480).jpg
ID:	155488   Click image for larger version
Name:	engine left side - Copy (640x480).jpg
The Following 4 Users Say Thank You to Epley For This Post:
Old 01-20-2013, 10:41:52 PM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
Both engines pictured have water pumps and magnetos. The shaft shown has a pulley on the left, a water pump in the center and the mag with horseshoe magnets on the right. Obviously the same engine.
Old 01-21-2013, 03:08:03 AM
The OU, per a 36 King products catalog, doesn't seem to share parts with very many other Budas...
Piston is its own; wrist pin is shared with the TU, but apparently came in two types: set screw and lock ring (the set screw and lock ring show for other Budas, but I assume these're commodity items, so didn't list..
Bearings, both rods and three mains, are shared with the QU and TU.
Valves are also shared with the QU and TU; no guides, springs or keepers are listed, but presumably they'd share them as well. Again, basically commodity items.
A 1930 McCord gasket catalog doesn't list any of the three, not a good sign as to widespread use...a 33 Perf Circle ring catalog lists dates for some engines (I have no idea how accurate the dates are) and shows the OU as 1913-28, the QU as 1912-23 and the TU as 1913-26, so you'd think a 1930 catalog would list at least the OU and TU (the assumption being that if they were limited use engines McCord might've not gotten enoigh calls to put them into the 1930 catalog)...
---------- Post added at 02:08 AM ---------- Previous post was at 02:00 AM ----------
Mroz's truck book says per some records first Republic built 1912 by Alma Motor Truck Company. 1913 models were 3/4 and 1Ton and remained the same for 1914 when name changed to Republic Motor truck Company. For 11915 there were three shaft drive and two chain drive models, that by the end of 915 chain drive was discontinued and Torbenson Internal Gear drive was advertised...don't know if that's any help as to pinning down year or not...
Old 01-21-2013, 10:46:26 PM
Bud this is a big help. This truck is bigger than a 1 ton and has an internal gear drive axle but it is not a Torbenson. It has internal and external brakes we just took all that apart to ease restoration. We believe it is a 2 1/2 ton front wheels weigh 175 lbs solid rubber, wood spokes. Back wheels are bigger and heavier. The engine info is appreciated I couldn't find anything on the OU engine. As John said the engine that Pete has and ours are the same design. We have rebuilt the mag and the cracked water pump is being repaired. Truck before disassembly is attached. It is now striped to the frame and that is being sandblasted. The engine is off to an overhaul shop. One wheel has been restored. Interesting project.
Name:	As received.jpg
ID:	155625   Click image for larger version
Name:	buda engine - Copy (640x639).jpg
The Following 2 Users Say Thank You to Epley For This Post:
Old 01-22-2013, 03:09:23 PM
Finally thought to eyeball some older catalogs (which I should've done first--had my brain in low and my mouth in high) and didn't find anything definitive (parts catalogs are weak reeds to lean on) but did find interesting things...
A 24 piston catalog listed three Budas, but not your OU...only listing close to our years was the "T" 31/2ton 1916-17 with the Buda T and TU, 41/2 bore,which seems to've gone to the HU 41/4 bore for 1917-19...
A 1917 Burd ring catalog was much more interesting. Unfortunately this catalog is set up by ring size, under each size listing cars, trucks, engines etc using that size. Under Republic truck it lists (without any tonnage , again unfortunately):
1908-12---"all"--4 and 6 cyl--41/4 bore, 4 1/4 rings. This's one of the most popular sizes, and includes several Budas, three Cont'ls, a Hersh-Splmn, a Salter I'm unfamiliar with and an early Wauk "L", just in the 4s..
1913-14--model C--33/4 with 3 3/16 rings, a size which includes the Cont'l "C" and others; AND a second engine with 33/4 bore and 4 1/4 rings--DECIDEDLY CURIOUS as this size
lists NONE of the usual vendor engines with 4 rings. It does list a Rochester, which I'm unfamiliar with, and it includes a raft of other "assembled" trucks, so could be a misprint or omission ...
1914-16 (in index) Model N, also with two sizes:
(a) 1914-16 with 31/2 bore, 3 3/16 rings, fitting Cont'l "N" and others; and:
(b) 1915-16 with 33/4 with 3 3/16 rings, fitting Cont'l "C" and others (possible upgrade or option??)...
1915-16--model OU--41/8 bore with 3 1/4 rings, fitting the Buda OU and a couple other Budas...(probably yours??)...
1915-16--model TU--41/4 with 3 1/4 rings, fitting Buda TU and others.
For 1917 models 9 and 10...
Another 1917-26 catalog with no engine info indicates numbered models began in 1917 but some letter models continued to 1918, which DOES NOT agree with other dates shown above, illustrating how parts catalogs are inconsistent/confusing...
With sympathy, Bud
---------- Post added at 02:09 PM ---------- Previous post was at 01:59 PM ----------
Oh--look at you data plate carefully; there was also a Republic with a QU Buda...
Old 01-22-2013, 07:10:21 PM
Bud
Thanks for the look ups good info. To your last the data plate is very clear it is definately an OU. We are sending it off tomorrow to the engine shop so may have more info later the sizes will help. I am not be answering for a while we are off on a trip Saturday to South America and Antarctica back in three weeks. Thanks again for the help. Clint
Name:	engine buda name - Copy (640x337).jpg
Old 08-21-2013, 07:30:27 PM
adam g adam g is offline
I have a Model 10 Republic pickup. Need help with finding a right front wheel and would love to see what the redone one looks like ,, Thanks
Anyone Going to Republic Mo? T.R.W. Steam Stationary Engines, Traction Engines 2 09-08-2008 08:56:06 PM
Republic MO show photos markcorson Steam Stationary Engines, Traction Engines 3 09-16-2007 06:59:32 PM
Republic, MO Swap Meet Charlie Bryant Antique Engine Archives 4 04-08-2004 10:51:06 AM
Show in Republic, Mo Ken Stuempges Antique Engine Archives 3 09-12-2003 08:31:17 AM
Republic Mo. swap meet Richard Jensen Antique Engine Archives 1 02-14-2003 12:11:01 AM
