Hit & Miss Gas Engine Discussion Meet collectors of hit and miss engines, ask questions about collecting, restoring and showing antique flywheel engines. |
What parts do you need?this thread has 1137 replies and has been viewed 170344 times
#81
I pickd up a Hercules 1 3/4 hp engine and found the governor bracket is broken at the two bot holes. Anyone have a useable one available?
Sponsored Links |
#82
I need correct muffler for 1 1/2 hp appleton
#83
We've got this (I think) 3hp Fuller and Johnson NB we saved from a scrap dumpster. We just need a few more pieces to get her going.
#84
Would anyone out there have a kerosene carb for a bates and Edmonds - Fairbanks Bulldog 2 1/2 hp ?
I have a 2.5 bulldog horizontal that has the fuel pump just like the verticle. Thank you for any help. Randy Hart
He who dies with the most STUFF wins! |
#85
Hello, I need the Speed control assembly for a 1.5hp Economy type E. A picture is posted in wanted items.
#86
Need mixer for 1 1/2 little jumbo model P. no flang slips into 1 3/8 hole one set screw holds it in.
#87
Chasing any White Gasoline Engine parts especially 8hp,
thanks Siz ![]() |
#88
Anybody have a Fairbanks rocker arm casting # 27ND1 ?
#89
I need a 2" friction wheel for my Motsinger auto sparker.I would also like to ask if someone has one and is willing to let me borrow it I would fabricate up a few.
#90
I am also in need of the Cast iron cone shaped piece that fastens to the Carb. on a New Idea Vari-Speed engine.
"So Much Iron & So Little Money" ![]() |
#91
I need a sub base for a 2 1/2 Waterloo or contract engine. Thanks.
#92
I am in need of a ignitor for a 3hp famous. Also a Galloway carb
For a 3 hp roundrod. Thanks! |
#93
I need to try and find a fuel fill for a 6hp Sparta model B. I also need a cam gear for a 6hp Sparta model C ( it would be the same as on a CA or possibly a CX). Thanks Dave
#94
Looking for any available Waterloo Boy H 5hp parts. Thanks
#95
I need the intake valve assembly for a Cushman binder engine that uses the mechanical linkage (rocker arm) and the pushrod. The rocker arm is still on the engine. Like to find the Tillotson side draft carburetor too!
#96
Ray, sent you a PM. I may be able to help. George
#97
I need a water pump for a 4 cylinder Kahlenberg marine engine. Also anything else Kahlenberg related like whistles or a compresolite unit made by them with a briggs motor for power. Thanks
#98
I'm looking for a crank guard for a 3 hp type A Domestic and also a crank guard for a 7 hp tank cooled Alamo. Am also looking for the cast iron piece that sits on top of the cooling trays for the Alamo. Thanks
#99
Fairbanks Morse 2hp dishpan hit & miss;brass fitting fuel mixer nozzle & retaining clamp,speed control assembly & timer assembly,straight cut governor gear
Ferro 6hp marine twin;timer cover,waterpump,float bowl & carb airhorn Cushman 4 hp binder engine;intake valve and cage assembly older shorter version |
#100
I need a head for my 6HP FM Z.
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
I Need Parts Parts For (2A042) (MEP-017A) | Raymond56 | Military MEP and Aircraft Gen-Sets | 7 | 10-27-2011 08:47:51 AM |
1946 evinrude parts list & parts | Lou Quirch | Antique Marine Engines and Outboard Motors | 2 | 12-16-2009 06:51:34 PM |
Trade Delco 15c3 parts for 15c1 parts | MBreen254 | Generators & Electric Motors General Discussion | 1 | 03-09-2008 06:59:22 PM |
Online Onan Parts Sales-or at least a parts number | B.Ikard | Onan Generators | 3 | 06-21-2007 07:07:12 AM |
Fairbanks Morse type T parts list, parts. | Mike Rollins | Hit & Miss Gas Engine Discussion | 1 | 11-18-2006 04:53:36 PM |
