Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Gray 1 cyl 2 Stroke Gas Year & Info?
this thread has 4 replies and has been viewed 611 times
Old 05-23-2019, 06:26:18 PM
ricknriver ricknriver is offline
Default Gray 1 cyl 2 Stroke Gas Year & Info?
BTB a Gray. Came with 16' nice unrestored early 1900s fantail launch (unknown builder) but possible, not original. Possibly out of the upper mid-west. Cylinder head # 145R over 12567 on a brass plate on side of the cylinder, and raised "6-13" on cylinder casting. The "5" in 145R is actually a backward "S". Confusing. Hopefully future centerpiece of our new little Maritime Museum. Thanks, Rick
https://photos.google.com/share/AF1Q...84NkY2amh1SHNB
Old 05-23-2019, 10:38:20 PM
ScooterBob ScooterBob is offline
Default Re: Gray 1 cyl 2 stroke Gas Year & Info?
Any chance we can see some pictures??
Here's a link that shows how to post photos on this forum...
https://www.smokstak.com/forum/showthread.php?t=40589
Old 05-24-2019, 12:26:06 AM
A bunch here taken and uploaded by a friend. https://photos.app.goo.gl/UApjsDbVKH36GBdD7
Have to figure out how to separate and post on forum. R
The Following 2 Users Say Thank You to ricknriver For This Post:
Old 05-25-2019, 07:22:01 AM
Harry's Avatar
Default Re: Gray 1 cyl 2 Stroke Gas Year & Info?
A wonderful project, boat and all.
Originally Posted by Harry on PM:
https://www.old-engine.com/graymotr.htm
Thank you for the information. Now to find and assemble all the piece parts, and see if she'll run. Rick
Mine has the same water pump from Syracuse, New York.
Be careful with the gasket between the block and the crankcase as it seals the fuel/air incoming mix.
Also, you need a quick ignition by regular ignition coil as a buzz coil has its dwell too long.
(See our Terms of Service)
Old 05-26-2019, 01:32:29 PM
Thank you very much for the tips. All comments/thoughts welcome - getting "hooked" :-). R
Lanz - movie on starting an 80-year old two-stroke engine Darek Vintage Diesel and Oil Stationary Engines 1 02-13-2019 07:18:54 PM
Gray 4-stroke 5 hp. marine engine hms50 Antique Marine Engines and Outboard Motors 6 10-10-2016 09:49:14 AM
Gray year identification Josh. T. Antique Marine Engines and Outboard Motors 2 01-11-2013 10:26:43 PM
Clinton '61 4-stroke 3 1/4HP I'm looking for info on lbptoo Small Air Cooled Gasoline Engines 1 04-14-2012 11:21:15 AM
Gray 2 cyl info Gil Cramer Antique Marine Engines and Outboard Motors 1 04-08-2006 06:45:34 PM
