Go Back   SmokStak > Other Vintage and Antique Collectibles > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Antique Piston Water Pump
this thread has 3 replies and has been viewed 742 times
Old 06-02-2019, 08:56:43 PM
AZ Gary AZ Gary is offline
Default Antique Piston Water Pump
I'm going to try again, I posted this item a few months ago and got no feed back as to the manufacturer of this unit. It is a factory built unit but does not have any markings other than intake and discharge on each side of pump. It has a lever on drive shaft to put it out of gear while still running I have tried other forums but can't find one that may know what it is. I like to find all I can about equipment I own but this in one remains a mystery.
Thanks for any feed back.
Name:	Piston Pump 001.jpg
ID:	336194   Click image for larger version
Name:	Piston Pump 002.jpg
ID:	336195   Click image for larger version
Name:	Piston Pump 003.jpg
The Following 2 Users Say Thank You to AZ Gary For This Post:
Old 06-02-2019, 09:48:09 PM
Default Re: Antique Piston Water Pump
Neat!
Unfortunately I have no idea either. It reminds me that I have a weird little pump that I should post. Mine is gear driven...
Old 06-16-2019, 03:17:46 PM
Jeff P Smith Jeff P Smith is offline
I don't know either but it looks real pretty Gary
Old 06-16-2019, 06:28:04 PM
I've got it hooked up to the engine on a cart I built and going to build some sort of water feature. Pictures later.
Gary
Evinrude Water Pump - Antique Overkill66 Unidentified Engines 11 03-04-2018 01:48:50 PM
Internal rust in Piston Water Pump ronny p 148 Farm Antiques and Collectibles 1 05-22-2016 03:00:12 AM
Unidentified Piston Water Pump EngineCrank Smokstak Down Under 4 11-12-2015 01:32:03 AM
Old piston water pump ronny p 148 Farm Antiques and Collectibles 6 03-24-2014 11:12:28 PM
antique water pump question, please help!! civilwar1263 Hit & Miss Gas Engine Discussion 1 01-20-2014 09:44:41 PM
