Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Evinrude motor year made?
this thread has 6 replies and has been viewed 315 times
Old 10-25-2019, 06:09:08 PM
Jim Martin's Avatar
Jim Martin Jim Martin is offline
Default Evinrude motor year made?
A friend of mine picked up this little Evinrude motor the other day and was wondering about when it was made?
Name:	evinrude  m  .jpg
ID:	347506   Click image for larger version
ID:	347507   Click image for larger version
ID:	347508   Click image for larger version
Name:	evinrude m  sn.jpg
Old 10-25-2019, 08:19:18 PM
Walt Potoniec Walt Potoniec is offline
Default Re: Evinrude motor year made?
looks like a caille, not a evinrude.
The Following User Says Thank You to Walt Potoniec For This Post:
Old 10-25-2019, 08:31:05 PM
DustyBar DustyBar is offline
Some of these engines are hard to date because precise records weren't maintained. On my engine the date was determined by the Tillotsen carb. Perhaps you have a Tillotsen carb on yours and can find the model number on it. Then search the internet for that Tillotsen model number. There is a table on a web site that will then give you a good idea of the year built.
The Following User Says Thank You to DustyBar For This Post:
Old 10-25-2019, 09:21:46 PM
Jim Martin's Avatar
Thanks for the imput. I have a couple older evinrude's that have the name on the flywheel on top, also I will check the carb model as well.
Old 10-25-2019, 10:06:31 PM
Chad Johnson Chad Johnson is offline
I have a Tillotson list and an Evinrude serial number list and can look these up.
I've always found the Tillotson list accurate, I don't know enough about outboardsto vouch for the Evinrude list.
Hope this helps
Chad
The Following User Says Thank You to Chad Johnson For This Post:
Old 10-26-2019, 07:44:14 AM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Caille, and looks like a 5 speed RBM. Pricey little engine.
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
The Following User Says Thank You to Preston Wells For This Post:
Old 10-26-2019, 06:47:26 PM
JoeCB JoeCB is offline
It is a Caille 5-speed with the optional recoil starter. Check out "Jack Craib's Rowboat Motor "web site for more info and pix
Joe B
PS, that is Caille , pronounced "kay - el"
The Following User Says Thank You to JoeCB For This Post:
Evinrude Motor Co BigGoomba Hit & Miss Gas Engine Discussion 28 01-23-2013 08:43:46 PM
Help Identify Evinrude Motor with Tillitson carb redlinedave Antique Marine Engines and Outboard Motors 7 10-25-2011 08:46:22 PM
Information needed about an old Evinrude outboard motor packard1950 Antique Marine Engines and Outboard Motors 2 09-20-2011 01:20:32 PM
Evinrude 3HP Motor Jim Metzger Chain Saw Collectors 5 03-14-2011 04:26:03 PM
Evinrude Outboard Motor gnordy4908 Antique Marine Engines and Outboard Motors 9 10-24-2010 08:16:14 AM
