Steam Engines
Steam Stationary Engines, Traction Engines Antique steam engines, their boilers, pumps, gauges, whistles and other related things that make them run. Also Locomotives nad Railroads.
Bethlehem Blowing Engines Update
this thread has 3 replies and has been viewed 2243 times
Old 11-17-2008, 08:54:32 AM
todengine's Avatar
todengine todengine is offline
Default Bethlehem Blowing Engines Update
This past weekend I was out in Bethlehem with a couple of volunteers. When we arrived on Friday it was so warm and muggy that the interior of the blowing engine house was enveloped in fog. Saturday it rained for most of the day but we were able to try out a new and stronger degreaser which worked perfectly. When we got back into the building on Sunday morning the temp had dropped by about 20 degrees and that helped dry out the building and engine. With the engine prepped for painting I decided that it was now or never to put the paint on! I used an airless sprayer and did all of the painting in an hour and a half with minimal overspray.
Rick Rowlands
Curator & Chief Engineer
Youngstown Steel Heritage
http://www.todengine.org
Old 11-17-2008, 03:35:10 PM
GaarScott's Avatar
GaarScott GaarScott is offline
Default Re: Bethlehem Blowing Engines Update
What was the degreaser you used? The engine looks great in its new coat of green paint.
Lawrence
Old 11-17-2008, 04:04:09 PM
KG1584's Avatar
KG1584 KG1584 is offline
What type of engine are these. They look gargantuan.
Also - it looks like there are quite a few of these. What are some of the details of the engine house
Doug
Old 11-17-2008, 08:29:42 PM
todengine's Avatar
There should be links to similar threads in the bottom of this page about the Bethlehem engines. I put a bit of background about them in those threads.
For a degreaser we used a Gunk product called SC super concentrate. Its mixed with diesel fuel and works great. I spray it on and let it soak in then pressure wash off. Grease just lifts right off. I also use the same mixture in my parts washer at home. It seems counterintuitive but it leaves no oily residue on the cleaned surface.
Rick Rowlands
Bethlehem Gas Blowing Engines todengine Hit & Miss Gas Engine Discussion 36 05-02-2015 08:32:50 AM
Bethlehem Blowing Engines Work Session Report todengine Hit & Miss Gas Engine Discussion 8 07-15-2008 10:09:31 PM
Bethlehem Blowing Engines todengine Hit & Miss Gas Engine Discussion 0 06-15-2008 07:27:38 AM
Bethlehem Gas Engines Update todengine Hit & Miss Gas Engine Discussion 11 05-03-2008 08:22:58 PM
