Need help/info Chrysler 2 cycle industrial engine
this thread has 4 replies and has been viewed 4302 times
Old 07-19-2010, 11:52:53 AM
Eladortem Eladortem is offline
Default Need help/info Chrysler 2 cycle industrial engine
Chrysler 2 cycle industrial engine #50010 serial#5602 made in Hartford,Wis. This powers my Dayton Lightweight 6hp chainsaw model #3z191 which runs great until you start cutting.The intake is located up front in line with the pulp discharge of the chain.There is an aluminum cover over the intake which allows the air to enter from the rear along with the dust.Any attempts to add a filtering material other than a fine mesh screen chokes it dead.It has a 25" Swedish roller nose bar and is loud and throaty definitely not lightweight. Was this a flawed design combination being the reason for it's obscurity and lack of information on the web or am I the lost one?
Old 07-20-2010, 05:24:47 PM
Default Re: Need help/info Chrysler 2 cycle industrial engine
Don't know anything about these, but a thumbnail history on usmotors.com sez they're the successors to the Chrysler Power Bee line; they might be helpful. Good luck.
The Following User Says Thank You to Bud Tierney For This Post:
Old 07-24-2011, 02:57:50 PM
Moparman Moparman is offline
Do you still have this chain saw? I am looking at one and am concerned what the starter side of saw should look like. If you still have, I would appreciate it if you could send a photo of starter side and a view of starter side from top. Please send to pwatkins@valornet.com If I can find more information about it, I will let you know. Paul
Old 07-25-2011, 01:33:36 AM
Ken Karrow Ken Karrow is offline
If a parts break down is any help - try Grangers, Dayton is their house label brand and 3Z191 is typical of their numbering system.
Old 07-25-2011, 06:36:57 PM
I had a saw that acted the same way.Turned out that the cyl. was shot.Scored,flaking chrome.scored piston.It started easy but would make no power.
What have I got, chrysler 700 2 cycle Mac Leod Small Air Cooled Gasoline Engines 6 11-28-2011 01:26:40 PM
Liberty 2 cycle engine--Info. Needed! Jester Small Air Cooled Gasoline Engines 2 05-09-2009 08:50:27 PM
Info needed Chrysler 3.6 fuel/oil ratio Andrew Mackey Antique Marine Engines and Outboard Motors 4 05-30-2008 10:27:40 AM
info wtd on AC I-60,I-600 industrial??? Rob Charles Antique Farm Tractors with Rubber Tires 0 06-14-2005 11:50:57 PM
Chrysler 2 cycle engine Doug Barbee Antique Engine Archives 3 01-09-2003 01:16:27 PM
