Antique Steel Wheeled Mechanical Plows...History, Weed Finds, Prices, Parts, Etc.
this thread has 382 replies and has been viewed 94783 times
Old 01-11-2017, 08:48:05 PM
halcon halcon is offline
Default Re: Antique Steel Wheeled Mechanical Plows...History, Weed Finds, Prices, Parts, Etc.
It appears that disc plow is one of the later versions, just by looking at that arm casting with it's newer style IH logo and R1 suffix on the part #. |Maybe a number 9
The Following 3 Users Say Thank You to halcon For This Post:
Old 02-11-2017, 07:26:08 PM
53 Super M 53 Super M is offline
Annual FFA consignment auction was today and this followed me home:#8 Little Genius in 2-14s with the conventional btms missing only the counters for $40.00 which I figured I couldn't go wrong with. Last pic shows some of the original decalling.
The Following User Says Thank You to 53 Super M For This Post:
  #343
Old 02-11-2017, 07:29:09 PM
Here we go.
ID:	274673   Click image for larger version
ID:	274674   Click image for larger version
The Following 5 Users Say Thank You to 53 Super M For This Post:
  #344
Old 02-11-2017, 09:30:36 PM
Mark Schneider Mark Schneider is online now
Hey 53 Super M...I've got a plow just like that only on rubber and has the Super Chief bottoms with the 4 bolt shares. What's that bracket do-dad mounted on the coulter shank used for?
Old 02-11-2017, 10:48:20 PM
Mark,
That originally had the IH concave coulters on it,which the main bearing and blade assemblies are gone,only thing left are the brackets and stops. Plan on putting regular coulter assemblies on it if it pans out,kinda hope it does causethen I'll have a set of 2-14s to go along with my set of 2-12s. As said,can't go wrong for 40 bucks,worth that for parts.
Old 02-12-2017, 02:42:29 PM
Here's some shots of the shares and moldboards also the tailwheel which is in really good shape. Moldboards look to be stubble typeand usable,will probably build up the fronts of each one with hard surface welding rod along with the front landslide. Tailwheel has some cracks at the boltholes,will weld these also. Land wheel is little out of kilter,has a weave to twill try to get it straight again. Looks to be a good project.
ID:	274764   Click image for larger version
ID:	274765   Click image for larger version
ID:	274766   Click image for larger version
The Following 4 Users Say Thank You to 53 Super M For This Post:
  #347
Old 03-17-2017, 10:48:24 PM
Brian P Brian P is offline
My friends 1926 15-30 and a no8 5-12 P&O trip plough
The Following 6 Users Say Thank You to Brian P For This Post:
  #348
Old 03-17-2017, 10:50:49 PM
Here's another picture of the same rig
The Following 7 Users Say Thank You to Brian P For This Post:
  #349
Old 03-18-2017, 04:07:04 PM
Plough weight? We got some 3 furrow ploughs today from a friend cleaning up a yard. They are tractor drag type ploughs. Some are IHC. Does anyone have an idea what the shipping weights might be? He just wants scrap price for them so we could figure something out by weight. The IHC ones have fairly heavy beams and there is also a Cockshutt that seems heavy built. No pictures yet.
Thanx.
Old 03-18-2017, 07:02:31 PM
Good looking outfit. Looks like the only thing that plow needs is coulters. Don't see too many 5 -12"btm plows around.
Old 03-18-2017, 07:06:37 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
That's gotta be scarce, looks like a great outfit. Hopefully it shows up at Le Sueur this year for the IH feature.
Tim Colwell
JD & IHC corn sheller and engine collector.
The Following User Says Thank You to Tim Colwell For This Post:
  #352
Old 03-27-2017, 02:18:51 PM
It'll be at the le seuer show this August
The Following User Says Thank You to Brian P For This Post:
  #353
Old 04-07-2017, 10:15:43 PM
Squatch253 Squatch253 is offline
Hey guys, I recently picked up this John Deere plow on steel, wondering if anybody can help me identify what model it is, and maybe age? It looks more like a 2-12" setup than a 14", but I'm not sure. Flat steel frame beams, riveted construction. Land wheel has the axle wrapping around it, doesn't look much like most of the other old JD plows in that respect.
The Following User Says Thank You to Squatch253 For This Post:
  #354
Old 04-07-2017, 10:21:02 PM
This plow beam has "520" stamped on it.
The other beam has "521"
It's also got cool looking John Deere lettering on the housing by the tail wheel.
Anybody have any ideas of what model this one is? It doesn't look quite as heavy in construction as the other JD plows I have.
The Following 3 Users Say Thank You to Squatch253 For This Post:
  #355
Old 04-08-2017, 12:26:54 AM
Charlie1925 Charlie1925 is offline
Nice looking plow, It looks to be in good shape and very useable. It appears to be a 2 / 14 inch.
The Following User Says Thank You to Charlie1925 For This Post:
  #356
Old 04-08-2017, 08:35:14 AM
LukeSte LukeSte is offline
It would be a model 45 or 46 plow. Build 1922 to 23 per the beam numbers
The Following 4 Users Say Thank You to LukeSte For This Post:
  #357
Old 04-08-2017, 10:15:34 AM
Thanks guys, that's the info I was after.
Old 04-30-2017, 06:17:36 PM
TSeaberg TSeaberg is offline
Did some spring cleaning with a few of my project Massey plows this weekend. They are all arranged from oldest to newest.
The Following 9 Users Say Thank You to TSeaberg For This Post:
  #359
Old 04-30-2017, 08:00:40 PM
Demoman Demoman is offline
Nice collection
The Following User Says Thank You to Demoman For This Post:
  #360
Old 04-30-2017, 08:39:57 PM
Here is my latest plow project that is nearly done. This one is a 1939 Massey Harris #3 that was sold new in Pembina ND in 1939 along with a Massey Harris 101 super standard. It stayed on the same farm until I bought it in 2009. This plow had been used a bunch and plenty worn out. Lots of new square bolts to replace odd ones installed through the years, one new wheel to replace a bent and rusted original, new lift hub, new bushings to tighten up the wheels along with welded up axles, rebuilt coulters, new hitch, straighten all the bent original pieces. Still waiting on new plow bolts to finish the bottoms, and one pesky hubcap.
The Following 8 Users Say Thank You to TSeaberg For This Post:
Old steel wheeled tractor in a movie model k rumely Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 54 12-30-2016 04:41:01 PM
IHC steel wheeled wagon JHuggans Farm Antiques and Collectibles 0 01-19-2013 08:09:04 PM
Another Steel Wheeled H Nebraska Cowman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 08-12-2012 06:05:17 PM
Steel Wheeled Farmall H daleed Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-09-2011 08:01:41 PM
Steel wheeled wagon JIMnWV Horse Drawn Equipment 2 09-30-2010 08:09:00 PM
