Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Antique Machine Tools (Pre 1930)
New Haven Lathe
this thread has 8 replies and has been viewed 724 times
Old 04-15-2018, 02:37:03 AM
blaw blaw is offline
Default New Haven Lathe
Hey fellas, Anybody got a clue what a 28x96 New Haven Lathe would weigh?
Thanks
Bryan
Old 04-15-2018, 09:42:10 AM
Default Re: New Haven Lathe
You need to post some pictures to get an estimate.
Old 04-15-2018, 10:17:43 AM
Rob Charles Rob Charles is offline
Card Sponsor
My Sidney 27" by 10' which is a geared head weighs around 10 tons Rob
Old 04-15-2018, 04:03:11 PM
Motormowers's Avatar
That is an incredibly rare machine. I've never seen any New Haven machines and I live here. They were built at 30 Whitney Ave New Haven CT at whats now down in the heart of Yale Univ.
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Old 04-15-2018, 04:31:35 PM
Here is the Craigslist ad that he was looking at.
https://billings.craigslist.org/tls/...557182194.html
ID:	308352   Click image for larger version
ID:	308353   Click image for larger version
Old 04-15-2018, 06:15:17 PM
No problem getting that one into the basement shop
Old 04-15-2018, 09:20:15 PM
Card Sponsor
I'm thinking 5 tons. Looks bigger than 28" swing. Rob
Old 04-15-2018, 10:50:02 PM
GarysToys GarysToys is offline
Take that small chuck off and you will lose a pound or two.
Also if you remove the tail stock, that should take a few more pounds off.
I found that turning a carpet runner over and putting it under the piece allows you to easily pull heavy pieces across the floor.
This should help when sliding it down the basement stairs.
Don't forget to check if there is enough clearance at the bottom of the stairs to allow the Lathe to be turned into the basement.
You may want to get some of those moving dollies at HF, One on each end should do.
However. if it falls through the basement stairs you should have plenty of room to move it around in the basement.
Nice machine.
I certainly hope you don't take me seriously.
The Following 2 Users Say Thank You to GarysToys For This Post:
Old 04-16-2018, 08:36:11 AM
Thanks to Rob on Practical Machinist the lathe weighs 5800 plus some for the transmission and motor on it. If it was closer I might be interested in it.
New Haven-Flat Belt-Engine Flywheel Lathe Steve V. Hit & Miss Gas Engine Discussion 6 06-05-2012 09:49:27 AM
International LB you probably haven't seen before SDP Hit & Miss Gas Engine Discussion 10 04-26-2011 11:06:32 PM
So I haven't been to an auction... krawlr Live Auctions of Engines, Tractors and Old Iron 8 05-11-2009 11:37:24 PM
haven't checked in Harry Eisenhauer III Hit & Miss Gas Engine Discussion 0 07-15-2007 06:36:42 PM
