Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Paperwood Pulleys
this thread has 11 replies and has been viewed 962 times
Old 04-23-2019, 11:31:26 AM
Russ Hamm's Avatar
Images: 1
Default Paperwood Pulleys
I know there are companies that rebuild these but has anyone done their own? Seems like if there was a way to fabricate the many layers needed out of something it could be done. Just curious.
I just got done reading the history of the Rockwood company and saw that they were actually bought out by the current paper pulleys company, interesting read. Looks like for afety reasons a guy should really go with them on rebuilding a paperwood pulley.
Old 04-23-2019, 12:11:18 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: Paperwood pulleys.
I believe that the paper pulley co is the same outfit as Rockwood. The employees of the pulley division bought out their division and separated from the big corporate main co., as the head management decided to close out that somewhat obsolete technology division. Likely, if we want that group to survive for the future help in our hobby, we should keep them busy with our patronage.
The Following 3 Users Say Thank You to FWurth For This Post:
Old 04-23-2019, 01:08:22 PM
gasenginerick gasenginerick is offline
I had two custome pulleys made by Paper Pulleys inc from Tennessee, I was very happy with them.
The Following User Says Thank You to gasenginerick For This Post:
Old 04-23-2019, 01:37:47 PM
www.paperpulleys.com
The Following 3 Users Say Thank You to casertractor For This Post:
Old 04-23-2019, 05:36:07 PM
Steve Kunz's Avatar
Steve Kunz Steve Kunz is offline
I had Paper Pulleys inc. do the pulley on my Keck Gonnerman gas tractor. They did a nice job. See post 4 on this thread.
https://www.smokstak.com/forum/showt...keck+gonnerman
Steve Kunz
The Following 2 Users Say Thank You to Steve Kunz For This Post:
Old 04-24-2019, 07:42:16 AM
Andy Williams Andy Williams is offline
good to see they are still in business. i guess one could be made from layers of plywood glued and then turned in a wood lathe. I never done it but it looks it would work
Old 04-24-2019, 10:58:14 AM
WD Garrett WD Garrett is offline
This was a paper pulley replaced by layers of plywood glued and bolted together.
Bill
Name:	massey 8 (Medium).JPG
The Following User Says Thank You to WD Garrett For This Post:
Old 04-24-2019, 07:35:50 PM
Gene Williams Gene Williams is offline
Default Re: Paperwood Pulleys
We had paper pulleys do one for our 20-40 Case. We were in a hurry and needed it now. They delivered and it fit as well as if Case would have sold it in 1918. It was perfect bolts holes matched our hub and everything (they did not have our hub).
Old 04-26-2019, 09:11:35 PM
JFred's Avatar
JFred JFred is offline
Are you saying that they already had one in stock for your model case?
Old 04-26-2019, 10:06:12 PM
FWurth's Avatar
One Millionth Post
Images: 4
I believe they still have the old original patterns for most applications.
Old 04-27-2019, 07:55:42 PM
Alan Svanes Alan Svanes is offline
I have a friend that have made a couple of pulleys out of hardboard and I trued them up on the lathe. If I remember it took more than a 4x8 sheet to do a 16 inch pulley.
Alan
Old 05-11-2019, 12:55:34 PM
Avery22x36 Avery22x36 is offline
Would be interesting to see how they made them, before I knew you could order them new, I was going to take masonite and use Gorilla Glue and an 80 ton press to make a cube and then lathe it down.
Pulleys and Parts? Bill in Oregon Maytag Engines and Collectibles 14 10-07-2017 09:44:46 AM
sleeving pulleys and such randyt Machine Shop and Tool Talk 7 12-30-2011 06:56:27 PM
PTO Belt Pulleys Rex Piekarczyk Antique Farm Tractors 1 10-15-2008 09:56:27 PM
Arranging pulleys Blair Hit & Miss Gas Engine Discussion 1 07-08-2008 07:05:28 PM
Pulleys and such.... Pete Wygant Hit & Miss Gas Engine Discussion 8 09-03-2006 04:32:12 PM
