Steam Engines
Ashton Valve Co Steam Gauge Tester
this thread has 13 replies and has been viewed 3682 times
Old 02-18-2015, 11:54:08 PM
greasyjesse greasyjesse is offline
Default Ashton Valve Co Steam Gauge Tester
I'm hoping someone will have some info on this Ashton dead weight tester. Serial no. 325 has original iron box weights and fittings. Is there somewhere I can try and find records of where this was sold or to what company? Let me know what ya think. Thanks
ID:	218953   Click image for larger version
ID:	218954   Click image for larger version
Old 02-18-2015, 11:59:41 PM
Default Re: ashton valve co steam gauge tester
Forgot to mention it has a brass tsg Ashton valve company Boston Massachusetts and it is solid brass with Nickel plating
Old 02-19-2015, 02:19:40 AM
Not sure what you are asking for. Ashton was the manufacture. Would have been sold by any company who sold gauges and accessories. Purpose was calibration of gauges. In use gauge is connected to open port. Weights on stand push against piston in ratio to piston size. Pressure is increased by screw pump until weights float free. (give platform a gentle spin as you screw up pressure.) Read pressure on gauge and adjust as needed in comparison to weight/ratio. In some cases gauge needle is removed and replaced at propper reading. Other gauges had zero and span adjustments.
A very useful device when needed, but mostly a wall decoration in between. New ones cost over a thousand dollars, but older models like yours can be found fairly cheap.
It it works use it. They are inherently accurate as long as weights haven't rusted enough to offset accuracy.
Doc
---------- Post added at 11:19 PM ---------- Previous post was at 11:07 PM ----------
Here's some info in an old add: https://books.google.com/books?id=ki...tester&f=false
The Following 2 Users Say Thank You to Thaumaturge For This Post:
Old 02-19-2015, 08:22:16 AM
Peter Peter is offline
I would like to find one fairly cheap complete and working with the weights in the box. Well then cheep is a relative term. I dont consider $500 cheap. But sure missing weights and other issues, can get you down in the cheep range fast. This is avery desirable instrument for the steam engineer or person.
An indicator might often live it life time at a certain site with a specific engine and that is can be an interesting provenance. This type of instrument would more often be in a shop or facility that supported a large number of boilers. You might determine the year or manufacture. And you did say you wanted to know where is was sold from and not to? Maybe?
As for sales records there is a chance. Maybe you will never know who the initial buyer was. I will send you a (greesyjessy) a private message with name and contact info for person, I believe he has the company records. Definitely no promise. You could get lucky.
---------- Post added at 07:22 AM ---------- Previous post was at 07:16 AM ----------
Greasy,
I sent an email. That is the email you provided when you registered. Please let me know if you got that. I know sometimes we make up bogus/temp emails for website registration purposes. If needed I can use private message.
I hope this helps.
The Following 2 Users Say Thank You to Peter For This Post:
Old 02-19-2015, 10:25:44 AM
Joe K Joe K is offline
Still, like Steam Indicators (No 1) and Planimeters (No. 2) and Revolution Counters (No. 4) among the MUST HAVE for any steam engineer.
Well, at least a 19th century steam engineer.
Funny, I have made a 20th and 21st century career of steam and have not used ANY of these devices in my work.
I think we've lost something along the way.
BILGEWATER on computer aided engineering.
Sorry. Channeling my inner Marmaduke.
Joe K
The Following 2 Users Say Thank You to Joe K For This Post:
Old 02-19-2015, 10:31:19 AM
wmusta wmusta is offline
Joe K , I suppose you don't wear stripped coveralls or hat either!
Old 02-19-2015, 10:46:06 AM
No and Dad (another steam engineer) used to smoke a cigar - but didn't wear a plug bowler.
But I have the hat and overalls - waiting. Maybe these are No. 5 and No. 6 of the must have?
Joe K
Old 02-19-2015, 10:51:14 AM
David's Avatar
David David is offline
Back to the original topic.
Ashton was absorbed into the Crosby Steam Gauge and Valve Company, and all records were destroyed many years ago.
Star Brass Mfg. Co. was also absorbed into the Crosby family. All three were based in Boston, MA.
David
The Following User Says Thank You to David For This Post:
Old 02-19-2015, 11:35:46 AM
David
Actually, a little more on this (and to add to that from Peter above)
Crosby Steam records and documentation are available. Catch Craig Bliss's site http://www.crosby-steam.com/
He can be talked to directly with a phone call or Email (see the site) and likely he has records of your instrument.
Craig is one of the premier "keepers" of the flame.
I need to talk to him to get drawing copies of the little square metal bottle used to catch the oil under the Crosby Deadweight Tester. Mine is missing the bottle.
Not shown but goes below the petcock handle.
Joe K
The Following User Says Thank You to Joe K For This Post:
Old 02-19-2015, 02:52:36 PM
I thank you for the insight and for the link to old advertising much appreciated
Old 02-19-2015, 04:31:47 PM
Now the cat is out of the bag! ha ha, I did not have a link to that site and I am surprised his phone is there. My email has a know good phone, FWIW.
An added note, although his maybe on that website and mention in the last post. All the blueprints for Crosby whistles are available. I was able to make an exact duplicate part for a whistle even though I was unable to borrow one. Wonderful resource.
"Keeper of the flame", exactly.
Old 06-05-2019, 05:01:07 PM
Ashton Ashton is offline
It's almost impossible to pin a date on something like this. I don't believe they tracked the testers by serial numbers like they did with the gauges. Here are a few attachments that you might find interesting. The catalog page is from around 1920.
ID:	336453   Click image for larger version
ID:	336454   Click image for larger version
ID:	336455   Click image for larger version
ID:	336456   Click image for larger version
The Following 2 Users Say Thank You to Ashton For This Post:
Old 06-19-2019, 02:01:17 PM
Ashton valve made a few different styles of gauge testers. Here are a few pictures of some of them.
ID:	337451   Click image for larger version
ID:	337452   Click image for larger version
ID:	337453   Click image for larger version
Old 06-22-2019, 10:06:53 AM
Default Re: Ashton Valve Co Steam Gauge Tester
And some catalog info about them.
ID:	337664   Click image for larger version
ID:	337665   Click image for larger version
Ashton Valve Company Ashton Steam Stationary Engines, Traction Engines 16 08-19-2019 05:11:50 PM
Ashton Valve Instruction Book (1917?) Ashton Railroads and Equipment 1 06-05-2019 01:29:37 PM
Prime Gauge Tester Information Needed kpny1961 Steam Stationary Engines, Traction Engines 6 05-15-2018 05:49:14 PM
Looking for audio gauge/thickness tester in Los Angeles Mister Tawny Machine Shop and Tool Talk 1 07-09-2009 09:03:14 PM
Dead weight gauge Tester - weights Peter Steam Stationary Engines, Traction Engines 13 05-31-2008 04:50:14 PM
