Bed Planer weight - 12' Hendrie & Bolthoff
this thread has 7 replies and has been viewed 2691 times
Old 09-16-2014, 03:32:42 PM
Anvil Mountain Anvil Mountain is offline
Default Bed Planer weight - 12' Hendrie & Bolthoff
I recently acquired an antique flat belt powered bed planer. I need to determine the weight so I can rent the appropriate forklift. It's made by The Hendrie & Bolthoff Mfg. and Supply Co of Denver. The entire frame is 12' long with a traveling bed length of 6'. Any ideas to it's weight - I'm estimating about 8000lb, but need to be sure?
Thanks in advance,
Lowell
Name:	12' bed planer.jpg
ID:	206034   Click image for larger version
Name:	bed planer - end.jpg
Old 09-16-2014, 05:05:40 PM
Mike Grivna Mike Grivna is offline
Default Re: Bed Planer weight - 12' Hendrie & Bolthoff
Lowell, you should be able to find some info on this site.
http://vintagemachinery.org/
Old 09-16-2014, 10:33:30 PM
Thanks for the link Mike - I've done some digging on the Vintage Machinery site but found nothing on this machine's weight.
Old 09-20-2014, 01:08:43 PM
ronm ronm is offline
Are you sure the Hendrie & Bolthoff ID isn't a dealer plate? H&B used to be a big tool dealer in Colorado, I don't think they manufactured anything, but I could be wrong...I remember a H&B store in Grand Junction when I was a kid. Later turned into American Parts.
I used to have a ball-pien hammer from H&B, lost it somewhere along the line.
Edit: googled around, & H&B did in fact build mining equipment, so it's possible they did make planers...the reference I found said it's not clear whether they built or sold rebadged equipment by other builders. They were quite a prominent company in Denver.
here's a link:http://vintagemachinery.org/mfgindex/detail.aspx?id=961
Old 03-18-2015, 06:15:39 AM
Henry Maudslay Henry Maudslay is offline
Look carefully-you,ll probably find it is a Cincinnati make. Ted
Old 03-18-2015, 10:21:23 AM
I think my 10,000 # would get lite with that, and next size up is 15,000# machine weighing in at at least 20,000#. remember ratings are pretty close to middle of forks with about 3' of lift .
Old 03-24-2015, 05:09:29 PM
alskdjfhg alskdjfhg is offline
A "heavy" Cincinnati 24" planer weighted 6200lbs, the standard weighed 5000lbs. 500lbs per extra foot for the heavy and 400 for the standard.
Not an exact match, but should give you an idea.
---------- Post added at 04:09 PM ---------- Previous post was at 04:07 PM ----------
Looking back, the planer looks very much like a Cincinnati from the teens, so my number in the previous post are probably pretty close.
Old 07-10-2019, 01:26:13 AM
Marius Titulescu Marius Titulescu is offline
Thanks for the detailed explanation. I think I saw one of these models at Chariots GCS.
My new, Old Planer Peter Machine Shop and Tool Talk 5 01-23-2011 08:50:50 AM
Old Planer Mill Wayne Riedlinger Farm Antiques and Collectibles 4 11-09-2009 07:46:44 PM
Three sided planer michael j henson Farm Antiques and Collectibles 5 09-30-2008 08:47:19 PM
Planer Doug Smith Antique Engine Archives 5 01-12-2004 11:40:11 AM
