Fiat 702 Tractor
this thread has 41 replies and has been viewed 6237 times
Old 12-18-2017, 11:21:54 PM
Oilpulled Oilpulled is offline
Default Re: Fiat 702 Tractor
Phil-Post 19: That's the way to repair cast iron. I've done it a little on a manifold. Heat it in a charcoal fire, weld and then bury everything in wood ashes. It's hot work!
The Following User Says Thank You to Oilpulled For This Post:
Old 12-20-2017, 01:09:52 AM
Charlie1925 Charlie1925 is offline
Phil Johnson, Norm Johnson and Aultman Taylor; If anyone of you guys ever worked on a Allis Chalmers model " L " built between 1922 & 1927 you would have ran into bolts and nuts that are also WHITWORTH. I ran into that back in 2009 -2011 when I was reworking my " L " Allis Chalmers, I too was a little puzzeled as to what was going on. Brake out the metics and all sizes of adjustables. Keep us posted on this project. Roger Weinhold AKA Charlie 1925.
Old 12-20-2017, 02:04:10 AM
Phil Johnson's Avatar
Not a problem here, Charlie as I also play with old Brit sports cars so have a pretty complete set of whitworth tools, wrenches and sockets.
As for Allis 'L', I have had the chance to work on one that a friend had here for a while. There are three in this area that I am aware of.
It'll be done in good time---impossible might take a little longer!
The Following User Says Thank You to Phil Johnson For This Post:
  #24
Old 12-21-2017, 03:17:03 PM
Norm Johnston Norm Johnston is offline
Since restoring the Avance tractor I have gained several spanners and sockets with measurements in 32 nds and these do fit the odd ones in between metric and imperial in 16 ths. keep up the good work
The Following User Says Thank You to Norm Johnston For This Post:
  #25
Old 03-06-2018, 04:03:24 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Any updates Phil?
Tim Colwell
JD & IHC corn sheller and engine collector.
Old 03-06-2018, 10:44:48 PM
It is a 703. Still waiting on the engine block which is still at the welding shop. A new dual fuel tank is being made and should be ready soon. It's kind of a complicated thing to make.
The Following 3 Users Say Thank You to Phil Johnson For This Post:
  #27
Old 03-14-2018, 08:54:00 AM
Davide L. Davide L. is offline
Hi Phil,
i have missed your thread about this amazing machine! AS David Parfitt wrote to you, it's a fiat 703. IF you need any help with the engine please let me know. I have several documentation on early fiat tractors.
Good luck with the restoration! I will be waiting for updates!
Ciao from Torino, where this tractor was built.
Davide
The Following User Says Thank You to Davide L. For This Post:
  #28
Old 03-15-2018, 11:16:59 AM
The engine welding is on hold for a while as Cal, the welder, has a broken finger and can't do any welding for another couple of weeks!!
I got the new fuel tank from Robb, the sheet metal man. It is a two compartment tank and the fuel selector valves mount on the boss on the bottom. I do some sheet metal work, but I don't have his skills with it!!
ID:	305632   Click image for larger version
ID:	305633   Click image for larger version
ID:	305634   Click image for larger version
The Following 5 Users Say Thank You to Phil Johnson For This Post:
  #29
Old 12-10-2018, 11:20:38 PM
I'll give it a bump again its been about 8 months. Phil, Any updates on the 703?
Tim Colwell
Old 12-11-2018, 12:23:22 PM
The engine block was successfully welded and I got it back some months ago. I was advised to let it age for a while like a new casting due to all the heating and cooling cycles it had gone through.
The block, rods and pistons are now at the machine shop as the bores will need sleeves as #1 and #2 had weld into the bore and 3 and 4 had grooves in the walls due to loose wrist pins. Sleeves will have to be custom made for this application.
Turning out to be an expensive repair!!
  #31
Old 07-15-2019, 11:09:48 PM
TractorDom's Avatar
TractorDom TractorDom is offline
what is the latest news?
Old Habits like old iron die hard
Old 07-15-2019, 11:20:45 PM
Well timed!!! I was just about to post an update as I finally just got the block etc. back from the machine shop. It was a long wait as the sleeves had to be custom made due to their length and then the shop is really busy with their regular work which is custom rebuilding diesel engines for many customers.
I have a couple of other projects (not tractors) in progress at the moment and will probably get going again on it next week.
The Following 7 Users Say Thank You to Phil Johnson For This Post:
  #33
Old 07-19-2019, 07:10:14 PM
David Hoover David Hoover is offline
Here’s a Fiat ad from the Canadian dealer...
The Following 5 Users Say Thank You to David Hoover For This Post:
  #34
Old 08-01-2019, 09:59:52 PM
I finally got some time to work on the engine for the Fiat. Here are a few pics of the block after all the welding and machine work. Cal did an exceptional job on the welding and finishing as it's hard to tell that the block had all those cracks!
ID:	340565   Click image for larger version
ID:	340566   Click image for larger version
ID:	340567   Click image for larger version
Old 08-01-2019, 10:02:12 PM
The machine shop had to special order the custom sleeves to fit this headless block due to their extra length. They bored #2 and #3 and installed the sleeves and then honed them to give the proper clearance for the pistons.
I spent quite a bit of time today cutting the bevel reliefs for the con rods in the bottom of the sleeves. They left that for me to do!
I carefully cut the edges close to finished size with a good hacksaw and then cut the sleeve section out with a small diamond wheel. From there i ground it out closer with a 3/4 in belt sander and then finally finished with a good flat machine file and a very good light.
ID:	340569   Click image for larger version
ID:	340570   Click image for larger version
ID:	340571   Click image for larger version
The Following 10 Users Say Thank You to Phil Johnson For This Post:
  #36
Old 08-01-2019, 10:15:51 PM
I had a broken Hart Parr casting welded by Cal a month ago, probably one of the best cast welders in existence!
The Following User Says Thank You to David Hoover For This Post:
  #37
Old 08-02-2019, 10:33:54 PM
Brasherman Brasherman is offline
Wow, that looks great! I see what you mean about getting expensive.....
Old 10-20-2019, 07:56:48 PM
I've made a little progress on putting this project back together. I had to make all new rod bolts as the old ones were in pretty tough shape. Rods and pistons are installed, fitted into the block and the block is bolted back onto the crankcase with a new gasket. All gaskets have to be made as there is not much available for this engine.
The valves were in very good shape and just needed a light lapping to ensure good seating. Next is installing valve springs and setting valve clearance which is 2/10mm or .008 for intakes and 6/10mm or .025 for exhaust.
I lost my camera for a while, but it has now turned up so I'll have to get some more pics on here. Too many other projects in the shop!!
The Following 2 Users Say Thank You to Phil Johnson For This Post:
  #39
Old 10-20-2019, 08:17:08 PM
I missed that last update, That block turned out really nice, can't even tell.
Tim Colwell
Old 11-02-2019, 10:51:30 AM
Here are the pics of installing the block down over the pistons.
ID:	348120   Click image for larger version
Australian auction with Fiat 702 Tim Colwell Smokstak Down Under 5 09-19-2016 04:43:03 AM
28.4 litre Fiat tapkoote Antique Autos and Trucks 2 01-03-2015 04:42:39 PM
Fiat 880-5 and 980 Danielrooi Antique Farm Tractors 2 05-27-2014 03:19:29 PM
Fiat 880-5 and 980 Danielrooi Vintage Diesel and Oil Stationary Engines 0 05-20-2014 02:03:22 PM
Fiat Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 08-05-2006 05:05:09 PM
