Oliver 77 Three point
this thread has 2 replies and has been viewed 244 times
Old 07-17-2019, 10:30:18 AM
VicF VicF is offline
Images: 4
Default Oliver 77 Three point
Hi, I was recently doing some skimming in my Oliver 77 manual and found that there is a section about three point hitches. I assume this is a factory option as mine does not have one. Has anyone added one using a kit like this https://www.yesterdaystractors.com/H...EaAljaEALw_wcB
Thanks
The Following User Says Thank You to VicF For This Post:
Old 07-17-2019, 12:59:12 PM
John Schwiebert John Schwiebert is offline
Default Re: Oliver 77 Three point
There were 2 different factory 3 point hitches for the model 77 tractor. Later on there was a different 3 point for the Super 77 tractor. I worked for an Oliver dealer and we probably serviced close to 100 model 77 tractors and maybe 5 or 6 had a 3 point hitch. You don't find those add on hitches around here. All the tractors here on the farm have a 3 point hitch yet only one gets used.
The Following User Says Thank You to John Schwiebert For This Post:
Old 07-17-2019, 11:21:58 PM
ulgydog56's Avatar
regardless 3 point systems sure are handy thou....
Oliver 77 & Oliver Super 77 Parts Book / Manual TractorDom Service Manual Scans 4 04-18-2019 10:40:22 PM
Ford 2N Oliver with Oliver E 729 Loader bigGURN Antique Farm Tractors 1 09-07-2012 10:43:37 PM
Farmall 460 two point to three point hitch conversion, your thoughts? dalmatiangirl61 Antique Farm Tractors 6 04-10-2011 01:27:03 AM
Point Gap trashman6062 Hit & Miss Gas Engine Discussion 4 03-04-2009 03:20:39 PM
F/M J MAG need Point Gap Roger` Antique Engine Archives 1 03-26-2000 10:54:38 PM
