Welding Shop
Miller AE-AD 200le welder
this thread has 1 replies and has been viewed 155 times
Old 07-18-2019, 08:22:25 AM
1989bwood 1989bwood is offline
Default Miller AE-AD 200le welder
Hey guys my 1966 Miller AE-AD 200le engine drive welder runs great (Onan CCK-MS) it also generates AC power but when I switch it to DC weld it either wonít strike an arc at all or if it does it will be really hard to keep it going and it welds like crap. Iíve cleaned up the brushes on the generator but I donít know what else it could be. Any info is appreciated
Old 07-29-2019, 09:25:05 PM
Colin O Colin O is offline
Default Re: Miller AE-AD 200le welder
I would check your leads and ground cable first. I had a bad lead on one of mine. I had to cut off the last 5 feet and then it welded good.
Also the Onan has an adjustment screw on the bottom of the carburetor. If the engine bogs when striking an arc this will cause bad weld or an inability to weld. You have to turn it counter clockwise a quarter turn at a time until the engine smooths out under load. Another issue could be the resistors that attach to the plug in out puts. I had an issue with 2 different machines where where 1 resistor was broken and 1 had broken the spot weld attaching it to the next one in series. If the spot weld is broken you may get some arc but as the engine vibrates the resistor it will be intermittent and / or may stop welding altogether. I rolled a hole and bolted it back together and this worked
Another issue would be the RPM setting or govenor set up. If the engine rpm is to low you could get no arc or a poor arc.if the govenor spring tension is not proper then you would lose arc under load.
Miller AEAD-200LE Beisert Welding Shop 10 01-22-2018 11:49:36 AM
anybody know what onan motors are in old miller arc welder AEAD 200le carl hite Onan Generators 1 08-28-2015 12:45:14 AM
miller aead 200le marvgarr Welding Shop 2 08-23-2013 01:47:58 PM
TIG set up for my Miller AEAD 200LE? cweaver7018 Welding Shop 2 11-13-2010 10:22:45 PM
Miller AEAD-200LE welder-generator Lil Joe Welding Shop 2 10-17-2010 01:35:22 AM
